1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: time drift in camonitor timestamps
To: inari badillo <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Tue, 08 Jan 2013 17:51:15 +0100
To answer your original question...
Yes, this problem is known and documented since ~2.5 years, but not fixed yet [1].
Even though people have been running into this issue every now and then (there was even support added to devIOCstats [2] to measure the error), no-one's pain was bad enough to invest the time to track it down and fix it.
For >99% of the applications, it just does not matter if the scan period has an error in the order of a few promille.
~Ralph
[1] https://bugs.launchpad.net/epics-base/+bug/597054
[2] http://www.slac.stanford.edu/grp/cd/soft/epics/site/devIocStats/
On 08.01.2013 16:16, inari badillo wrote:
Thank you for your replies,
The magnitude of the error is about 700 microsecond (average), no matter the SCAN value is. So, it takes about 24min to have a 1s error.
Answering Michael Davidsaver´s question, I mean precessing relative to the start time. The different does not increase every cycle. Sorry if it wasn´t clear.
And finally yes, it seems reasonable to be caused by processing time. But in this case, wouldn´t it lead to malfunction?
Thanks again,
Inari Badillo
2013/1/4 Maren Purves <[email protected]>
If there's a genuine drift I'd expect that to be something like
the SCAN value + the processing time.
Maren
Michael Davidsaver wrote:
I mean, the difference between two
consecutive samples is always higher than the SCAN value, accumulating an
error.
Just to make certain I understand you.  Do you mean that the difference
increases with each iteration?  Or that the scan start time is moving
(precessing) relative to start of the system clock's second?
In case you have not seen it, the code in question is periodicTask().
http://bazaar.launchpad.net/~epics-core/epics-base/3.15/view/head:/src/ioc/db/dbScan.c#L561
On 1/3/2013 4:36 PM, Mark Rivers wrote:
What is the magnitude of the error?  How long does it take before the
error is 1 second, for example?
-----Original Message-----
[mailto:[email protected]] On Behalf Of
[email protected]
Sent: Thursday, January 03, 2013 3:09 PM
To: [email protected]
Subject: time drift in camonitor timestamps
We have realized that when monitoring periodic PVs, provided by soft
IOCs in
standard machines under Windows/Linux/MacOS, it is observed a drift in
the
timestamps (server time) . I mean, the difference between two
error.
It seems that  this issue does not occur in RT systems such as VxWorks
(as
expected).
We are wondering if this is a known issue. In our opinion, this fact
could
lead to
malfunction problems, especially if it is not taken into account.
Does anyone in the list experienced this problem?
thank you
Re: time drift in camonitor timestamps Eric Norum
time drift in camonitor timestamps ibadillo
RE: time drift in camonitor timestamps Mark Rivers
Re: time drift in camonitor timestamps Michael Davidsaver
Re: time drift in camonitor timestamps inari badillo
Prev: Re: time drift in camonitor timestamps inari badillo
Next: Re: time drift in camonitor timestamps Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
