1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Extensions installation for newbie
To: EPICS Tech-Talk <[email protected]>
Date: Thu, 10 Jan 2013 13:32:35 +0100
Sorry, I was wrong.
Somewhere is a ".." too many.
In general, the following should work:
Create a new dir, cd into it
Unpack extensionsTop_20120904.tar.gz
cd extensions
Set configure/RELEASE to
   EPICS_EXTENSIONS=$(TOP)
   EPICS_BASE=<wherever_your_base_is>
make
Good luck!
~Ralph
On 10.01.2013 12:32, Ralph Lange wrote:
Hi Mike,
you seem to be using an EPICS 3.13 extension tree, trying to compile against a 3.14 base.
Please start with an extension configuration that matches you base version.
The EPICS Extension page [1] has tars for both.
Good luck!
~Ralph
[1] http://www.aps.anl.gov/epics/extensions/index.php
On 10.01.2013 12:25, Michal Vítek wrote:
Hello,
I am new to epics and Linux and I am trying to install the Epics base with some extensions (MEDM, asynDriver, and stripTool). The base installation went fine, but now  I am having a problem during „make“ of the extensions. I think it is related to the files that needs to be modified, so far I have changed 2 (make file in the extensions top directory and RELEASE file of the extensions). Could somebody tell me what am I doing wrong ?
Cheers, Mike
OS: Scientific Linux 6
Extensions Make file:
TOP = /opt/epics/extensions
include $(TOP)/configure/CONFIG
DIRS = $(wildcard configure src)
include $(TOP)/configure/RULES_TOP
Extensions Release file:
EPICS_BASE=/opt/epics/base
EPICS_EXTENSIONS=/opt/epics/extensions
Log from make:
make -C ./configure install
make[1]: Entering directory `/opt/epics/extensions/configure'
make -C O.linux-x86_64 -f ../Makefile TOP=/opt/epics/extensions/.. T_A=linux-x86_64 install
make[2]: Entering directory `/opt/epics/extensions/configure/O.linux-x86_64'
../Makefile:5: /opt/epics/extensions/../configure/CONFIG: No such file or directory
../Makefile:9: /opt/epics/extensions/../configure/RULES: No such file or directory
make[2]: *** No rule to make target `/opt/epics/extensions/../configure/RULES'.  Stop.
make[2]: Leaving directory `/opt/epics/extensions/configure/O.linux-x86_64'
make[1]: *** [install.linux-x86_64] Error 2
make[1]: Leaving directory `/opt/epics/extensions/configure'
make: *** [configure.install] Error 2
Extensions installation for newbie Michal Vítek
Re: Extensions installation for newbie Ralph Lange
Prev: Re: routing Ralph Lange
Next: Re: routing Pavel Maslov
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Extensions installation for newbie Ralph Lange
Next: dbScan.c: periodicTask( ), initOnce( ), ... Jack Smith
