1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: data smoothing record
To: tech_talk <[email protected]>
Date: Wed, 16 Jan 2013 12:11:29 -0800
You could use an ai record with the SMOO field set to a non-zero value.
- rolf -
On 1/16/2013 12:01 PM, D Peter Siddons wrote:
Is there a record which can swallow a stream of data from a source (e.g. an ADC) and take a running average of N values and output it?
Pete.
| Rolf Keitel, Ph.D.                Tel: (604) 222-7453 |
| TRIUMF                                                |
| Vancouver, B.C., Canada                               |
data smoothing record D Peter Siddons
Prev: Re: data smoothing record Pavel Maslov
Next: Re: data smoothing record Southern, Tim
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: data smoothing record Dudley, David
