1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: femto and std
To: Tech Talk <[email protected]>
Date: Sun, 20 Jan 2013 09:37:16 -0600
I followed the thread on techtalk but did not find a solution to the problem regarding building std.
I don't have a 64 bit machine. I'm using 3.14.11 and std-3.1 or std-2.8 and seq-2.1.11. This does
build on a couple of other machines I'm using.
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m32     -g -fPIC -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include    -I/home/controls/support/seq/include  -I/home/controls/support/asyn4-19/include -I/home/epics/base-3-14-11/include/os/Linux -I/home/epics/base-3-14-11/include        ../pvHistory.c
make[3]: *** No rule to make target `femto.o', needed by `libstd.a'.  Stop.
Pierrick
"Whether you think you can or think you can't, either way, you are correct" -- Henry Ford
_______________________________________________________________
Pierrick Hanlet
IIT/Fermilab
+1-630-840-5555 (FNAL)
+1-312-567-5745 (IIT)
+1-630-697-8758/+44-79-48-860-197 (US/UK mobile)
Re: femto and std Tim Mooney
Prev: Re: Alter Perl hashbang in capr.pl Andrew Johnson
Next: Re: femto and std Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Alter Perl hashbang in capr.pl Shankar, Murali
