1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Can't read MIME Types file
To: Pierrick Hanlet <[email protected]>, Tech Talk <[email protected]>
Date: Mon, 28 Jan 2013 06:22:16 -0500
Hi:
Did you try the “ArchiveDataServerStandalone” as described in section 4.3.5 of http://ics-web.sns.ornl.gov/kasemir/archiver/manual.pdf with the DemoData directory?
That directory contains an example setup which includes abyss.conf and  an abyss/ subdir with mime.types etc.
Once that works, follow the manual directions:
"..copy all “abys*” files and directories from there <meaning: DemoData directory> into the directory where you intend to run the standalone data serve"
That way, you should have the abyss/mine.types file in the right place.
Kay
_______________________________________
From: [email protected] [[email protected]] On Behalf Of Pierrick Hanlet [[email protected]]
Sent: Sunday, January 27, 2013 5:46 PM
To: Tech Talk
Subject: Can't read MIME Types file
Hi all,
I have a linux box running 2.6.18-274 with epics 3.14.11.
I'm attempting to use the Channel Archiver stand alone abyss web server.  Using
the ThirdParty software, I successfully built everything that I need (I think). Yet
when I attempt to start the stand alone data server, I get the error message:
"Can't read MIME Types file 'abyss/mime.types'
This is simply an ascii file.  It exists and has similar permissions to other builds that
I have.  Any ideas on this?
BTW, this is a separate thread than my 32bit to 64bit question.  I urgently need this
information, so I'm trying on another machine for the moment.
Pierrick
"Whether you think you can or think you can't, either way, you are correct" -- Henry Ford
_______________________________________________________________
Pierrick Hanlet
IIT/Fermilab
+1-630-840-5555 (FNAL)
+1-312-567-5745 (IIT)
+1-630-697-8758/+44-79-48-860-197 (US/UK mobile)
Can't read MIME Types file Pierrick Hanlet
Prev: Can't read MIME Types file Pierrick Hanlet
Next: unable to tunnel CA through ssh tunnel Andre Charbonneau
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
