After playing a bit with the SSH tunnel and EPICS_CA_NAME_SERVERS, it
seems that it works fine when I use 'localhost' as opposed to my
system's IP address.
For example, my SSH tunnel is created as follows:
ssh -N my.epics.server -L 5064:localhost:5064
Then I set the following environment for EPICS:
EPICS_CA_AUTO_ADDR_LIST=NO
EPICS_HOST_ARCH=linux-x86
EPICS_CA_ADDR_LIST=
EPICS_CA_NAME_SERVERS=localhost:5064
Then it seems that with the above configuration, the ca_test command
happily uses the SSH tunnel to query my EPICS server.
Andre
On 13-01-28 09:22 AM, Andre Charbonneau wrote:
> Greetings everyone,
> I'm trying to do something rather simple but can't seem to get it to work.
> What I'm trying to do is the have my CA client to connect a CA server
> via a SSH tunnel. The CA client is running on a Windows system, and the
> SSH tunnel is created using Putty.
> Creating the SSH tunnel for port 5064 between the server and client,
> using PUTTY, seems to work fine.
> Then I set my Windows environment to have the following (as documented
> at http://www.aps.anl.gov/epics/base/R3-14/12-docs/CAref.html#Environmen):
> EPICS_CA_NAME_SERVERS=<localhost_ip_address>:5064
> EPICS_CA_ADDR_LIST=
> Then when I try to access one of my PVs using the CA client, I get the
> following error message:
>> C:\program files\EPICS Windows Tools>caget motorController:TestBox_1:C1
>> CA.Client.Exception...............................................
>> Warning: "Empty PV search address list"
>> Source File: ..\udpiiu.cpp line 359
>> Current Time: Fri Jan 25 2013 16:30:15.057180376
>> Channel connect timed out: 'motorController:TestBox_1:C1' not found.
> At this point I'm not sure if any traffic is actually going through the
> SSH tunnel or not. :-|
> Is a second tunnel for port 5065 also required?
> Anyone managed to get a similar setup working?
> Any information about this would be much appreciated.
> Thanks,
> Andre
André Charbonneau
Research Computing Support Analyst
Shared Services Canada | National Research Council Canada
Services partagés Canada | Conseil national de recherches Canada
100 Sussex Drive | 100, promenade Sussex
Ottawa, Ontario K1A 0R6
Canada
[email protected]
Telephone | Téléphone: 613-993-3129
- unable to tunnel CA through ssh tunnel Andre Charbonneau
memory and vxWorks based IOCs James F Ross
<2013>
2025
2026
Re: unable to tunnel CA through ssh tunnel Till Straumann
<2013>
2025
2026
