1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: memory and vxWorks based IOCs
To: [email protected]
Date: Tue, 29 Jan 2013 17:31:06 +0900
Hi James,
My suggestion is not a right one to identify your memory issue, but you should try this if your experiment or test is running now and time is critical for you, this IOC is important for your task.
  * Limit GUI instances
* Tell People not to execute GUI, and provide them a screenshot of GUI on a web site
  * Identify how to access PVs in GUI.
if GUI simply uses 'caget', please use 'timeout' according to PVs' priority or requirement * Setup 'CA gateway' so GUI cannot access PVs connected to the IOC directly
  JH
On 01/29/2013 01:18 AM, James F Ross wrote:
Hello everyone,
I suppose this is more a vxWorks question than an epics question, but
here is the issue.
I've got a VME based IOC running here at STAR that is having memory
problems.  Basically we noticed this issue as every 24-48 hours the IOC
would lose communication and all GUIs associated with it would go
blank.  The solution is to re-start the IOC by rebooting the VME, but
doing this every day is not a good solution.
The epics is running on vxWorks, so I can use the memShow command to
show the memory usage at a given time.  I can see that as I open more
and more GUIs, the memory fills up.  At least part of the cause of the
loss of communication has to do with too many people opening GUIs
relating to this IOC at the same time.  However, I am not certain that
this is the only problem.
What I would like is to track the memory usage over time to see if there
is a time component as well as just too many GUIs being opened.  Does
anyone know how to do this in vxWorks?  Get it to print its memory usage
every minute or so to a log file or something similar?
Thanks
James
Jeong Han Lee, Dr.rer.nat.
Accelerator Division
Rare Isotope Science Project
Institute for Basic Science
70, Yuseong-daero 1689-gil, Yusung-gu,
Daejeon 305-811, South Korea
cell : +82-10-7363-2083
tel  : +82-42-878-8733
fax  : +82-42-878-8799
Prev: Re: copying archived data from 32-bit to 64-bit machine Pierrick Hanlet
Next: scan thread suspended Martin Konrad
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: memory and vxWorks based IOCs John Dobbins
