1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: memory and vxWorks based IOCs
To: "'James F Ross'" <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Tue, 29 Jan 2013 19:39:14 +0000
Depending on the model of your CPU card you may be able to buy a memory upgrade on the used market.  I recently upgraded all of our MVME2700 CPUs from 32MB to 64MB.  That will increase their useful lifetime significantly, since we were coming close to running out of memory with 32GB on our beamline IOCs.  It cost about $600 per card, which is a lot of money for 64MB of memory today, but is a lot cheaper than a new CPU card.
From: [email protected] [mailto:[email protected]] On Behalf Of James F Ross
Sent: Monday, January 28, 2013 10:19 AM
To: EPICS Tech Talk
Subject: memory and vxWorks based IOCs
Hello everyone,
I suppose this is more a vxWorks question than an epics question, but here is the issue.
I've got a VME based IOC running here at STAR that is having memory problems.  Basically we noticed this issue as every 24-48 hours the IOC would lose communication and all GUIs associated with it would go blank.  The solution is to re-start the IOC by rebooting the VME, but doing this every day is not a good solution.
The epics is running on vxWorks, so I can use the memShow command to show the memory usage at a given time.  I can see that as I open more and more GUIs, the memory fills up.  At least part of the cause of the loss of communication has to do with too many people opening GUIs relating to this IOC at the same time.  However, I am not certain that this is the only problem.
What I would like is to track the memory usage over time to see if there is a time component as well as just too many GUIs being opened.  Does anyone know how to do this in vxWorks?  Get it to print its memory usage every minute or so to a log file or something similar?
Thanks
James
Re: memory and vxWorks based IOCs John Dobbins
memory and vxWorks based IOCs James F Ross
Prev: RE: BOY number representation & display scaling Chen, Xihui
Next: Re: memory and vxWorks based IOCs John Dobbins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: memory and vxWorks based IOCs James F Ross
