1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Analog data acquisition in an EMI environment
To: Paul Sichta <[email protected]>
Date: Fri, 1 Feb 2013 18:45:23 +0400
Aha,
Interesting! I've just found out we have ordered the LKCO, and we are going to get it in a couple of weeks, cool. However, from what I can see on their web-site it is not IEC 61850 comliant. And its' sensing head is not flexible (a stiff square frame to mount on huge busbars).
Is there any one who can explain me, what does IEC 61850 give to a controls engineer? The NXCT representative said they can equipt their sensor with a Profibus/Ethernet module. And this is everything he knows on the topic. Do you think it's better to use ADC together with the sensor's analog output or Profibus/Ethernet may come in handy?
Paul, concerning your point-to-point fiber optic links. Do you lose accuracy (magnitude and time shift) after such conversions (ADC - fiber - DAC)? 0.1% at 150kAmps is 150A. Is the 0.1% crucial to your experiments?
You also mentioned redHawk. Theoretically, you could try EPICS on this real-time Linux, right? What do you use instead of EPICS then?
Thanks for your answers.
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Landline: +7 (812) 461 01 01
Analog data acquisition in an EMI environment Pavel Maslov
Re: Analog data acquisition in an EMI environment Paul Sichta
Re: Analog data acquisition in an EMI environment Pavel Maslov
Prev: Java, CAJ, DNS RE: CSS addr_list bug Kasemir, Kay
Next: RE: epics gateway error message Hill, Jeff
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Analog data acquisition in an EMI environment Paul Sichta
Next: Re: Analog data acquisition in an EMI environment Pavel Maslov
