1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: (epics-python) Cothread egg installation
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 5 Feb 2013 09:16:18 -0800
Yes, got it!
The import command is looking FIRST in the local directory and then in the PYTHONPATH
Given the directory layout in the egg source, you need to get out of the source tree to use the newly installed python libs.
E
To: [email protected]; [email protected]
Date: Tue, 5 Feb 2013 07:39:31 +0000
As Guobao has pointed out, if you try to import cothread from within its source directory then you might get unexpected results.  However, you can fix this problem by running this command (you don’t need sudo for this):
                python setup.py build_ext –i
This will ensure that _coroutine.so is built in the source directory, which is useful if you want to work with the sources.  However, as you’ve already run ‘python setup.py install’, also try changing to another directory and see if ‘import cothread’ works there.
I presume that you didn’t mean to write ‘cothread.utils’ below?  I don’t recognise it, you probably mean ‘cothread.catools’.
Sent: 05 February 2013 02:07
To: [email protected]; Abbott, Michael (DLSLtd,RAL,DIA)
Subject: (epics-python) Cothread egg installation
Michael,
I am in the middle of the installation of the epics4 masarService (python based Save Compare Restore)
Cothread is a dependency.
After downloading 2-8, I ran
sudo python setup install
Everything seems to run smoothly
Thereafter to test the installation, I do
$ python
Python 2.7.3 (default, Jul 24 2012, 11:41:40)
[GCC 4.6.3 20120306 (Red Hat 4.6.3-2)] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> from cothread.utils import *
Traceback (most recent call last):
  File "<stdin>", line 1, in <module>
  File "cothread/__init__.py", line 41, in <module>
    from . import cothread
  File "cothread/cothread.py", line 79, in <module>
    from . import _coroutine
ImportError: cannot import name _coroutine
What is going on?
Emmanuel
Lyncean Technologies
Palo Alto, CA
(epics-python) Cothread egg installation Emmanuel Mayssat
RE: (epics-python) Cothread egg installation michael.abbott
Prev: RE: (epics-python) Cothread egg installation michael.abbott
Next: Cannot connect to MASAR server Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
