We are using RS232. Using the XFlash unit as configured through spec does not show the same delay as the IOC. Disabling the Temperature monitoring PV (:ReadTemperature) which is on a 1s scan-rate, seems to alleviate the problem a bit. Thanks, -ZB On 2/6/13 11:00 AM, Phillip Sorensen wrote: > Hello, > > We are tring to setup the Rontec XFlash MCA with epics using the R7.2 > version of mca. > > The problem we are having is there seems to be a delay of some number of > seconds after sending a command until we see an update in the MEDM > screen. For example clicking the start and stop buttons for the > acquisition show this. I we look at the XFlash unit it seems to update > the front panel immediately, but the MEDM screen shows a delay. The > spectrum update (which is set to 1 second) also seems to take 5 to 10 > seconds per update. > > We are not getting any timeout errors. Any suggestions? Hi, Phil. Over what physical link are you communicating with the XFlash? If it's RS-232, it could just take that long to transmit the data over the slow link. Lewis
| ANJ, 20 Apr 2015 |
Home
News
About
Talk
Base
Modules
Extensions
