1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: AsynInt32 device support and mbbo records
To: "Mark Rivers" <[email protected]>
Date: 15 Feb 2013 15:45:11 +0100
Hey Marc,
the TMCM142_SAP in my example below is exactly what you suggest, only to code a different value.
The motor driver needs 3 parameters:
1) Byte 0 is the command number which codes things like "Move to position" or in the example below "Set axis parameter" (here I'm using pasynUser->reason). 2) Byte 1 Type/Parameter number. Some commands like "Set Axis Parameter" use this field to determine which axis parameter to read/write. In my opinion this is also a good candidate for the addr parameter. 3) Motor/Bank number. Axis related commands use this to distinguish between multiple axes, but our device
    doesn't support this.
From the hard- and firmware of the TMCM142 this parameter is currently only used by 2 commands, Set/Get global parameter, and only to access "user defined" global parameters.
Of course one could use the addr to code the 3rd parameter and use reason to code command and parameter numbers, but then you would end up with something around 500 strings or so...
Or is there any other way to pass a third paramter from the IOC to an asynPortDriver? I also thought about using the timeout, but that would be too confusing for others to use...
Best regards,
Florian
Am 15.02.2013 15:25, schrieb Mark Rivers:
Hi Florian,
In general I would recommend using pasynUser->reason for the "parameter number" and using the addr parameter for the "motor number".  That is more in the spirit of how they are intended to be used, and allows your driver to work with the next version of your motor controller which might support multiple axes.
Your db file would then look like:
record(ao, "$(P)$(R)Velocity) {
   field(DTYP, "asynInt32")
   field(OUT, "($(PORT),$(ADDR))VELOCITY")
ADDR is the motor number (0 for the current controller) and VELOCITY is the asynDrvUser parameter.
Your driver would implement the asynDrvUser interface to convert the string "VELOCITY" into the appropriate "parameter number", which it places in pasynUser->reason.
From: [email protected] [[email protected]] on behalf of Florian Feldbauer [[email protected]]
Sent: Friday, February 15, 2013 3:14 AM
To: EPICS Tech Talk
Subject: AsynInt32 device support and mbbo records
Hey,
I have written an AsynPortDriver for the TMCM142 1 axis stepper
driver/controller
The motor driver is connected via CAN bus and expects a message with 7
bytes of data:
byte 0: command number
byte 1: parameter number (I'm using the addr parameter from the asyn
interface)
byte 2: motor number (only one motor can be connected to the driver so
it is always 0)
byte 3-6: data (32 bit signed int)
For setting the microstep resolution of the motor driver the data has to
be a number between
0 and 11, each coding a different resoultion.
I wanted to use a mbbo record, which looks like this:
record( mbbo, "PANDA:$(subsys):MOTOR:$(SECTOR):SAP:USTEPRESOLUTION" ) {
    field( DTYP, "asynUInt32" )
    field( OUT,  "@asyn($(BUS),27,1)TMCM142_SAP" )
    field( ZRST, "2048 micro steps" )
    field( ONST, "1024 micro steps" )
    field( TWST, "512 micro steps" )
    field( THST, "256 micro steps" )
    field( FRST, "128 micro steps" )
    field( FVST, "64 micro steps" )
    field( SXST, "32 micro steps" )
    field( SVST, "16 micro steps" )
    field( EIST, "8 micro steps" )
    field( NIST, "4 micro steps" )
    field( TEST, "2 micro steps" )
    field( ELST, "1 micro steps" )
Unfortunately, the value inside my writeInt32 function from the
asynPortDriver is always 0.
Do I have to set the ZRVL,...,ELVL fields for asynInt32? Or do I need
another asyn interface for
this record?
Best regards,
Florian
| Dr. Florian Feldbauer                |
| Helmholtz-Institut Mainz /           |
| Johannes Gutenberg-Universität Mainz |
| Johann-Joachim-Becher-Weg 45         |
| D-55128 Mainz                        |
| Office: 01/217                       |
| Phone:  (+49)6131 / 39-25829         |
RE: AsynInt32 device support and mbbo records Mark Rivers
AsynInt32 device support and mbbo records Florian Feldbauer
Prev: RE: AsynInt32 device support and mbbo records Mark Rivers
Next: Re: record info field in which epics version? Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: AsynInt32 device support and mbbo records Mark Rivers
