Hi Euan,
On 2013-02-17 [email protected] wrote:
> I have an EPICS application that runs on Linux/Darwin where I need to
> increase the value of MAX_ARRAY_SIZE in aSubRecord.c from ten million to
> 200 million or possibly even 1000 million. Apart from creating a version
> of EPICS that is only locally compatible (and needing lots of memory to
> run) are there any likely problems with this change?
We have removed the MAX_ARRAY_SIZE limitation from the aSub record in the 3.15
branch of Base, although I don't think that's in any released version yet.
Your modified version should work fine.
- Andrew
There is no such thing as a free lunch. When invited for lunch,
it is best to check if you are there to eat, or to be eaten.
-- Clive Robinson
- aSub MAX_ARRAY_SIZE increase Euan.Troup
RE: aSub MAX_ARRAY_SIZE increase Dalesio, Leo
gateway: strange configuration Pierrick Hanlet
<2013>
2025
2026
Spring 2013 EPICS Collaboration Meeting: Registration Open ian.gillingham
<2013>
2025
2026
