On 2/21/13 10:15 , "haquin" <[email protected]> wrote:
>What I find disapointing is that the conversion forces the cast to Int32,
>for exemple, in my initial situation (asynFloat64 device support):
>- if I don't use the conversion the output is Float
>- if I use the conversion the output is Integer
>You never expect the conversion to prevent you from Float output.
You're correct. Conceptually, a linear conversion
VAR = RVAL * scale + offset
could operate on floating point data. But the AI, AO records happen to use
an integer RVAL.
If you need to perform a linear (or other) conversion and stay with
floating point, you'll have to use a CALC record. Can't use the LINR
options built into the AI, AO records. Yes, that can be inconvenient. With
EPICS, you get what you pay for.
-Kay
- Re: Rounding in conversion of ao record haquin
RE: Rounding in conversion of ao record Mark Rivers
<2013>
2025
2026
<2013>
2025
2026
