1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: CA beacon question
To: Tech Talk <[email protected]>
Date: Fri, 22 Feb 2013 13:51:15 -0600
Hi all,
I have a few soft iocs I'm running on a linux box running SL 2.6.18...  My epics
version is 3.14.11.  I have a similar configuration for another control system elsewhere.
Because I have multiple servers on a single processor, I generally assign them different
ports (initially set up by a former colleague). The ports I'm using are 6721, 6722, 6723,
and 6724.  The firewall is not set up on this machine, so I don't know if there is something
else that I should be doing in the configuration.
When I run my iocs, I get a lot of CA beacon errors when I run my iocs.
../online_notify.c: CA beacon (send to "148.79.117.13:6724") error was "Connection refused"
../online_notify.c: CA beacon (send to "148.79.117.13:6722") error was "Connection refused"
I've spent a lot of time reading the CA manual and looked through techtalk and haven't
found a definitive solution to fixing this.  I'm under the impression that I need to set the
beacon environment variable, but to what?
Pierrick
"Whether you think you can or think you can't, either way, you are correct" -- Henry Ford
_______________________________________________________________
Pierrick Hanlet
IIT/Fermilab
+1-630-840-5555 (FNAL)
+1-312-567-5745 (IIT)
+1-630-697-8758/+44-79-48-860-197 (US/UK mobile)
RE: CA beacon question Hill, Jeff
Prev: caClient with PCAS pthomas
Next: Re: caClient with PCAS Xiaoqiang Wang
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: caClient with PCAS pthomas
Next: RE: CA beacon question Hill, Jeff
