On 2013-02-22 Zhang, Dehong wrote:
> I seem to have such a problem: when my IOC starts up, some of my records
> want to callback almost immediately. Then my IOC crashes, because the
> "onceQ" related stuff are not created yet -- is this possible?
What device support are they using? The only way I could see this happening
is if those records are I/O Interrupt scanned and their device support is
calling scanIoRequest() before the global variable interruptAccept gets set to
true. If they try that, the scan request will be ignored (the associated
records will not be processed) which I guess might cause a crash.
> Is it safe to move the "scanInit" call in iocBuild to just before
> "initDrvSup" (EPICS base 3.14.12, src/misc/iocInit.c)?
No, you'll have to change your device support so it doesn't trigger until the
IOC is ready. One way to do that is to add an enable/disable which is
controlled by a bo record, and after iocInit your startup script would do a
dbpf to enable the device.
HTH,
- Andrew
There is no such thing as a free lunch. When invited for lunch,
it is best to check if you are there to eat, or to be eaten.
-- Clive Robinson
- Race condition during IOC startup? Zhang, Dehong
Re: Race condition during IOC startup? Michael Davidsaver
Re: EPICS Modbus module + PLC Pavel Maslov
<2013>
2025
2026
Problem when loading epics3.14.12.1 application to vxWorks5.5/MPC8572 王林
<2013>
2025
2026
