1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: caClient with PCAS
To: [email protected]
Date: Mon, 25 Feb 2013 16:27:03 -0800 (PST)
I was wondering where I might be able to find more information on
fileDescriptorManager.process. I am using this command as illustrated in
the examples to process events for a portable channel access server. Is
there a way to do this without calling it periodically? I seem to be
running into trouble doing this, because when I call it in a loop with
ca_poll, (or a usleep of more than 100000) it does not appear to be called
often enough and caget will time out trying to connect to channels in the
pcas.
Thank you,
Patrick
> Hi Xiaoqiang,
> Thank you for your response. I think it turns out that the problem was
> that I actually had preemptive callback enabled and I should not have. I
> think with preemptive callback enabled, the callback functions were being
> run while the fileDescriptorManager.process was processing. Now they only
> run when I call ca_poll or ca_pend_event, which I can separate from
> -Patrick
>> Hi,
>> It is difficult to say anything without looking at your source.
>> But one thing come to my mind is, you are using
>> fileDescriptorManager.process to poll for updates.
>> It would be good to test again using preemptive callback in caCleint
>> code.
>> Check here for more infos.
>> http://www.aps.anl.gov/epics/base/R3-14/12-docs/CAref.html#Thread
>> On the other hand, if you are not bound to use C++,
>> one can write such an application in Python, like I just did, in 3
>> minutes, 33 lines of code.
>> It uses module PCASpy[1] for PCAS server programming.
>> I use module CaChannel[2] for caClient, but other modules[3] should work
>> the same.
>> Best
>> Xiaoqiang
>> [1] https://code.google.com/p/pcaspy/
>> [2]
>> http://controls.web.psi.ch/cgi-bin/twiki/view/Main/NewPythonEpicsInterface
>> [3] http://www.aps.anl.gov/epics/extensions/index.php
>> On Feb 22, 2013, at 8:00 PM, [email protected] wrote:
>>> Hi,
>>> I am trying to add a portable channel access server to a channel access
>>> client, similar to the EPICS gateway I believe. The values for the
>>> process
>>> variables that are created by the PCAS are written to from the
>>> connection
>>> and event handler callbacks for the caClient. The problem I think I am
>>> running into, is that when I call fileDescriptorManager.process, these
>>> callbacks get called similar to as if a ca_pend_event was called. So
>>> after
>>> the call to fileDescriptorManager.process and before it completes, new
>>> values are being written to the PCAS process variables, and postEvent
>>> is
>>> being called for these changed values. This leads to funny behavior
>>> where
>>> the same value is posted for a PCAS channel multiple times in a row (as
>>> seen with camonitor). For example, it should post 1, 2, 3 but posts 3,
>>> 3,
>>> 3 instead, all with the same time stamps. Is there a way around this?
>>> I also ran a test, with just the PCAS and leaving out the caClient. I
>>> wrote to a PCAS process variable continuously with increasing values in
>>> one thread and called fileDescriptorManager.process continuously in
>>> another thread. This gave me similar results, that is the same value
>>> was
>>> posted multiple times in a row for stretches of time before it
>>> increased.
>>> I was not surprised that I got funny behavior doing this, but the fact
>>> that it was similar to the caClient helped me diagnose what may be
>>> happening.
>>> Also, what is the usual way to update the values for the PCAS process
>>> variables from the application itself (i.e. not with a caput)? I added
>>> a
>>> public function to the PCAS Server that calls functions in the
>>> appropriate
>>> PV instance to write a value and call the postEvent function. Is this
>>> typical? If so, I am guessing that I should also check in this function
>>> to
>>> see if the new value will actually be different before writing it, so
>>> that
>>> postEvent is not called when the value has not really changed? Or is
>>> there
>>> another way to do that?
>>> Thank you for your time,
>>> Patrick
Re: caClient with PCAS Xiaoqiang Wang
caClient with PCAS pthomas
Re: caClient with PCAS pthomas
Prev: Re: caClient with PCAS pthomas
Next: CA client on iOS? Pavel Maslov
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: caClient with PCAS Xiaoqiang Wang
