Hi Ben,
On 2013-03-01 Benjamin Franksen wrote:
> Am Freitag, 1. März 2013, 17:50:41 schrieben Sie:
> > The main
> > reason is that we have a dependency in place so that no cross-builds can
> > start until after the host build has completed. Those files will usually
> > be built and installed as part of the host build, so make will see them
> > as already up to date when it later checks them for each of the
> > cross-build targets.
> Thanks, I was not aware of this. Since when is this the case (i.e. only in
> 3.15 or is it in 3.14.12, too)?
This was added in 3.14.11 (see the Release Notes).
> And: will this same dependency (CROSS builds depend on HOST build to be
> complete) not also ensure that all architecture independent targets are
> already up-to-date when the CROSS build starts, so generating them directly
> inside $(COMMON_DIR) is not done multiple times in parallel? (Assuming, of
> course, that the rules are written to avoid accidental parallelism due to
> multiple targets in a non-pattern rule, as I explained in a previous
> message).
That's how we designed it work. However some people put conditionals into
their Makefiles which might disable the DBD file generation on the host for
example. Private rules that don't have correct dependency settings can also
result in the actions being run on all targets, and if the user never tries
parallel builds they might not notice this.
Problems with parallel builds can show up sooner or more often on Windows
because there the file-system won't let one process delete a file that another
process has open.
- Andrew
There is no such thing as a free lunch. When invited for lunch,
it is best to check if you are there to eat, or to be eaten.
-- Clive Robinson
- What I learned today... Benjamin Franksen
- Re: What I learned today... Andrew Johnson
- Re: What I learned today... Benjamin Franksen
RE: CA beacon question Hu, Yong
<2013>
2025
2026
<2013>
2025
2026
