1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: getBounds
To: Zenon Szalata <[email protected]>, tech-talk <[email protected]>
Date: Tue, 5 Mar 2013 00:47:10 +0000
Hi Zen,
If you look in asyn/asyn/devEpics/devAsynInt32.c you'll see that getBounds is called in initAi(), initAiAverage(), and initAo().
However, it is not called if the user specified the number of bits the device supports by using the asynMask syntax for the INP or OUT link specification.  That allows the device support to work correctly with Modbus and similar systems where a generic driver cannot know how many bits the device will support, so the database designer must define it.
- Are you using the asynInt32 device support for ai, aiAverage, or ao?
- Are you using the "asynMask" or "asyn" syntax in your link specification?
Can you send me a copy of the record definition in the .db or .template file?
Sent: Monday, March 04, 2013 6:14 PM
To: Mark Rivers; tech-talk
Subject: getBounds
Hi Mark,
I wonder when is the virtual function getBounds in asynPortDriver called.
I have reimplemented this function in my device driver.  I put a printf
statement in it and it looks that it never gets called.  I am thinking
that it should be called for each analog in or analog out record at IOC
init time.  That is not what I see.  What am I missing?
Zen
Re: getBounds Zenon Szalata
Prev: getBounds Zenon Szalata
Next: EPICS Record Support ahwwq
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: getBounds Zenon Szalata
