I meet the same problem here. I guess there may be some thing wrong
with RTEMS-beatnik's network driver, that it does not work in 1000Mbps
mode. The only workaround I found is to manually limit the Ethernet
interface to 100Mpbs mode in switch/router.
On Thu, Mar 7, 2013 at 2:56 PM, 문건영 <[email protected]> wrote:
> Hi all.
> I tried to run EPICS ioc in RTEMS-beatnik(MVME6100), I got the following
> error message
> ***** Initializing network *****
> Startup.
> Link detected; attaching mve1
> ***** Initializing NFS *****
> Mount 192.168.100.4:/var/lib/tftpboot on /home
> RTEMS-RPCIOD $Release$, Till Straumann, Stanford/SLAC/SSRL 2002, See LICENSE
> file for licensing info.
> RTEMS-NFS $Release$, Till Straumann, Stanford/SLAC/SSRL 2002, See LICENSE
> RPCIO: server '192.168.100.4' not responding - still trying
> Unable to contact NFS server - invalid port? (RPC: Timed out)
> mount failed: Unknown protocol
> development environment
> Epics base: 3.14.12.3
> Rtems: 4.10.2
> Os : centos 6.3 final
> NFS Mount test to NFS server from Remote host was successful. But, mvme6100
> was not.
> First of all, ping test failed from remote host to mvme6100.
> Please help me.
> As an another problem, mvme6100 have two Ethernet port,
> I want know how to set up in the rtems_netconfig.c
> Below the mvme6100 gevShow, boot process, the epics netstat log.
> Thanks you for your help.
> Regards.
> Mr. Mun.
> MVME6100> gevShow
> mot-script-boot
> tftpGet -c192.168.100.180 -s192.168.100.4 -m255.255.255.0 -d/dev/enet0
> -ftest.boot
> netShut
> go
> mot-/dev/enet0-cipa=192.168.100.180
> mot-/dev/enet0-sipa=192.168.100.4
> mot-/dev/enet0-snma=255.255.255.0
> epics-ntpserver=192.168.100.4
> epics-nfsmount=192.168.100.4:/var/lib/tftpboot:/home
> rtems-client-name=testIoc
> rtems-dns-server=192.168.100.4
> mot-/dev/enet0-file=test.boot
> Total Number of GE Variables =9, Bytes Utilized =385, Bytes Free =3207
> Copyright(C)2008-2009,Emerson Network Power-Embedded Computing,Inc.
> All Rights Reserved
> Copyright Motorola Inc. 1999-2007, All Rights Reserved
> MOTLoad RTOS Version 2.0, PAL Version 2.3 RM01
> Fri Jan 23 14:47:54 MST 2009
> MPU-Type =MPC74x7
> MPU-Int Clock Speed =1266MHz
> MPU-Ext Clock Speed =133MHz
> MPU-Int Cache(L2) Enabled, 512KB, L2CR =C0000000
> MPU-Ext Cache(L3) Enabled, 2MB, 211MHz, L3CR =DC026000
> PCI bus instance 0 =64 bit, 133 Mhz, PCI-X
> PCI bus instance 1 =64 bit, PCI
> Reset/Boot Vector =Flash1
> Local Memory Found =40000000 (&1073741824)
> User Download Buffer =006B7000:008B6FFF
> MVME6100> tftpGet -c192.168.100.180 -s192.168.100.4 -m255.255.255.0
> -d/dev/enet0 -ftest.boot
> Network Loading from: /dev/enet0
> Loading File: test.boot
> Load Address: 006B7000
> Download Buffer Size = 00200000
> Client IP Address = 192.168.100.180
> Server IP Address = 192.168.100.4
> Gateway IP Address = 192.168.100.253
> Subnet IP Address Mask = 255.255.255.0
> Network File Load in Progress...
> Bytes Received =&1710608, Bytes Loaded =&1710608
> Bytes/Second =&855304, Elapsed Time =2 Second(s)
> MVME6100>-----------------------------------------
> config addr is 0xF1000CF8
> config data is 0xF1000CFC
> Welcome to RTEMS rtems-4.10.2(PowerPC/Generic (classic FPU)/beatnik)
> CPU: MPC7457
> Board Type: MVME6100-0173 (S/N E0F85A0)
> Bus Clock Freq: 133333333 Hz
> CPU Clock Freq: 1266666654 Hz
> Memory: 1073741824 bytes
> Now BSP_mem_size = 0x3FC00000
> Configuration.work_space_size = A4D10
> Page table setup finished; will activate it NOW...
> Going to start PCI buses scanning and initialization
> Number of PCI buses found is : 3
> MSR 2003032
> Exit from bspstart
> unable to find the universe in pci config space
> Tundra Tsi148 PCI-VME bridge detected at 0x81100000, IRQ 84
> Tsi148 Outbound Ports:
> Port VME-Addr Size PCI-Adrs Mode:
> 0: 0x20000000 0x0E000000 0x90000000 A32, SUP, D32, SCT
> 1: 0x00000000 0x00FF0000 0x9F000000 A24, SUP, D32, SCT
> 2: 0x00000000 0x00010000 0x9FFF0000 A16, SUP, D32, SCT
> 7: 0x00000000 0x01000000 0x9E000000 CSR, SUP, D32, SCT
> Tsi148 Inbound Ports:
> 0: 0x90000000 0x3FC00000 0x00000000 A32, PGM, DAT, SUP, USR, MBLT, BLT
> vmeTsi148 IRQ manager: looking for registers on VME...
> Trying to find CSR on VME...
> vmeTsi148 - IRQ manager using VME CSR to flush FIFO
> Registering /dev/console as minor 0 (==/dev/ttyS0)
> Startup.
> rtems_bsdnet_get_ntp() Can't send: Host is down
> ***** Starting EPICS application *****
> testIoc>
> testIoc> netstat
> ************ INTERFACE STATISTICS ************
> ***** mve1 *****
> Ethernet Address: EC:9E:CD:09:72:85
> Address:192.168.100.180 Broadcast Address:192.168.100.255 Net
> mask:255.255.255.0
> Flags: Up Broadcast Running Simplex Multicast
> Send queue limit:50 length:0 Dropped:0
> mve1 Statistics:
> # IRQS: 7
> Max. mbuf chain length: 1
> # repacketed: 0
> # packets: 7
> MIB Counters:
> GOOD_OCTS_RCVD: 0
> BAD_OCTS_RCVD: 229348
> INTERNAL_MAC_TX_ERR: 0
> GOOD_FRAMES_RCVD: 0
> BAD_FRAMES_RCVD: 14
> BCAST_FRAMES_RCVD: 0
> MCAST_FRAMES_RCVD: 0
> FRAMES_64_OCTS: 7
> FRAMES_65_127_OCTS: 0
> FRAMES_128_255_OCTS: 0
> FRAMES_256_511_OCTS: 0
> FRAMES_512_1023_OCTS:0
> FRAMES_1024_MAX_OCTS:0
> GOOD_OCTS_SENT: 448
> GOOD_FRAMES_SENT: 7
> EXCESSIVE_COLL: 0
> MCAST_FRAMES_SENT: 0
> BCAST_FRAMES_SENT: 7
> UNREC_MAC_CTRL_RCVD: 0
> FC_SENT: 0
> GOOD_FC_RCVD: 0
> BAD_FC_RCVD: 0
> UNDERSIZE_RCVD: 0
> FRAGMENTS_RCVD: 14
> OVERSIZE_RCVD: 0
> JABBER_RCVD: 0
> MAC_RX_ERR: 0
> BAD_CRC_EVENT: 0
> COLL: 0
> LATE_COLL: 0
> ***** lo0 *****
> Address:127.0.0.1 Net mask:255.0.0.0
> Flags: Up Loopback Running Multicast
> ************ MBUF STATISTICS ************
> mbufs:16384 clusters:2560 free:2520
> drops: 0 waits: 0 drains: 0
> free:16342 data:42 header:0 socket:0
> pcb:0 rtable:0 htable:0 atable:0
> soname:0 soopts:0 ftable:0 rights:0
> ifaddr:0 control:0 oobdata:0
> testIoc>
Laurence Feng
Superconducting Radio Frequency Group
State Key Laboratory of Nuclear Physics and Technology
Peking University, 302 Chengfu Road
Beijing 100871 China
- Re: RTEMS-beatnik(MVME6100) network initialize error? Till Straumann
- RTEMS-beatnik(MVME6100) network initialize error? 문건영
RE: CSS Boy - creating OPI files with parameters Chen, Xihui
<2013>
2025
2026
<2013>
2025
2026
