Hi Mike,
On 2013-03-07 Westfall, Michael D wrote:
> Does anybody have any tips as how to communicate via a serial interface to
> a device that takes commands and gives responses in binary bytes rather
> than ASCII? We are using EPICS R3.13.4, and it appears that streamDevice
> is not available, or would require some extensive hacking to get it to
> work. devAscii is available, but since it relies heavily on string
> scanning functions, it will likely choke on any data that contain null
> bytes.
For 3.13.x we mostly used a C++-based module called MPF (Message Passing
Facility) for handling serial devices, which had its own UART drivers (I think
it could talk to a local serial port too, but I'm not 100% sure of that). It
was capable of handling binary messages, and could also use serial ports that
were connected to remote (slave) machines. However it might take a bit of
learning to adopt that.
I do have one driver and device support that directly opens a local serial
port on the vxWorks CPU board and does binary I/O through it, although it may
be more complicated than you'd like — it talks the Metasys protocol to Allen
Bradley PLCs. Whether the code's author (Bob Dalesio) can remember anything
about though I have no idea, but I can send you a copy if you'd like it.
- Andrew
There is no such thing as a free lunch. When invited for lunch,
it is best to check if you are there to eat, or to be eaten.
-- Clive Robinson
- Record support for binary serial communications? Westfall, Michael D
device support Sinclair, John William
Re: Automatic IOC configuration loading Bruce Hill
<2013>
2025
2026
Re: Record support for binary serial communications? Maren Purves
RE: Record support for binary serial communications? peter.owens
<2013>
2025
2026
