1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Channel Access
To: [email protected]
Date: Fri, 8 Mar 2013 00:05:53 -0600 (CST)
See "Channel Access Host Example" (section 2.3) in the Application Developer's Guide.
Here's a link:
http://www.aps.anl.gov/epics/base/R3-14/12-docs/AppDevGuide/node3.html#SECTION00330000000000000000
Running the command will make you an example ca client that accesses a record's field (also called a "pv").
The string you specify to refer to a record's field ("myRecord.VAL", for example) is called a "pvname".
Tim
----- Original Message -----
> From: [email protected]
> To: "tech-talk" <[email protected]>
> Sent: Thursday, March 7, 2013 9:32:03 PM
> Subject: Channel Access
> Hi,
> Does anybody know how to acess to a record's field using channel
> access in the client.
Channel Access ahwwq
Prev: Channel Access ahwwq
Next: Labview as Server and Probe as client, connection problem. Emir Drossa
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
