1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Automatic IOC configuration loading
Date: Fri, 08 Mar 2013 10:43:48 +0100
> The downside of this
> approach is that if your DHCP/NFS/PXE/BOOTP/TFTP server or servers are
> down, nothing boots.
We use local disks and FAI (http://www.fai-project.org/). The idea is to
use PXE and NFS to boot an installation system that can
reinstall/reconfigure a broken machine in a few minutes while at the
same time being able to operate the accelerator even if the central
NFS-Server is down. Thus this avoids the single point of failure (at
least for soft-IOCs running on Linux machines).
The FAI scripts can checkout IOC configuration from your Git repository,
copy files, run Perl scripts that retrieve data from a relational
database etc.
Cheers,
Martin
Dipl. Phys. Martin Konrad
Technische Universität Darmstadt
Institut für Kernphysik
Schlossgartenstr. 9
64289 Darmstadt
Tel.: +49-6151-16-5121
Fax: +49-6151-16-4321
Automatic IOC configuration loading Bruno Seiva Martins
Re: Automatic IOC configuration loading Bruce Hill
Prev: Labview as Server and Probe as client, connection problem. Emir Drossa
Next: RE: Record support for binary serial communications? peter.owens
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Automatic IOC configuration loading Bruce Hill
Next: Re: Automatic IOC configuration loading Bruno Martins
