1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: write record device support
To: tech-talk <[email protected]>
Date: Mon, 11 Mar 2013 22:09:47 +0800 (CST)
Hi all! Sorry for ask serveal simple questions.
Here is what I'm doing:
I had write a regular Ioc application connect with a board using TCP/IP socket. In the IOC, I use the system record type like ao, ai, bi and etc. So I have many records or PVs. And for each record I should send or receive different message to the board.
Now I want to write a new record type(nodeRecord) by myself instead of using system record type. Maybe it is not a good method.
But I want to have a try.
In the new record type(nodeRecord), I turn the previously IOC records to the nodeRecord's fields.
And I can access the fields in the client using ca library.
But I can't know what field was processed in the device support so that I can't konw what message I should send to the board.
So how do I konw which field I was processed in the device support?
Now I just compare the each field value and judge which field value was changed. This is too stupid.
Do you have any better ideals?
Thank you all!
RE: write record device support Mark Rivers
Prev: Trio Motion support for Motor Record Miroslav Pavleski
Next: I/O Intr scanning Vishnu Patel
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: write record device support Mark Rivers
