Hi Michael & Martin,
On 2013-03-11 Michael Davidsaver wrote:
> The added dependency is caused by a change I made to where libCap5.so is
> installed for the 3.14.12 series. Previously if was installed in
> /usr/lib/epics/lib, now it is under /usr/share/perl5 (I'll check, but I
> think it should actually be in /usr/lib/perl5).
You almost certainly won't be able to use a libCap5.so that was built against
Perl 5.10 on Perl 5.14. I introduced the Perl version number and architecture
into the path to libCap5.so to allow different Perl versions and architectures
to coexist in the same install directory.
> So avoiding the perlapi-* dep for epics-dev means moving (or removing)
> these scripts. My current plan is to move CA.pm, libCap5.so, and the
> scripts which use them to a separate binary package. Thoughts?
Sounds like a good idea. The Perl5 major version number matters for this
package, and it sounds like you might have to have more than one version of
that package available for install depending on which Perl5 version is in use
on the system — I would hope that dpkg can do something like that.
- Andrew
There is no such thing as a free lunch. When invited for lunch,
it is best to check if you are there to eat, or to be eaten.
-- Clive Robinson
- Re: epics-perl & perlapi-5.10.1 Martin Konrad
- epics-perl & perlapi-5.10.1 Martin Konrad
- Re: epics-perl & perlapi-5.10.1 Michael Davidsaver
Re: EDM Text Control Widget Motif behavior Isadoro Carlino
Save and Restore parameters Julio Calvo
<2013>
2025
2026
<2013>
2025
2026
