On 03/11/13 18:34, Andrew Johnson wrote:
> Hi Michael,
> On 2013-03-11 Michael Davidsaver wrote:
>> epics-dev gets a new dependency on "perl (>= 5.10.0)".
> As I said before, I don't think a libCap5.so built with Perl 5.10 is going to
> work if you try to load it into any other version of Perl (5.10.x might be Ok,
> but 5.12 or 5.14 will not).
Apologies for the lack of clarity. libCap5 is in 'epics-perl' not
'epics-dev'. For this reason I give 'epics-perl' a strict dep.
(perlapi-5.10.0).
> My point was that Ubuntu obviously has different Perl versions than Debian but
> Martin was still able to load your packages. BTW Perl 5.10 is over 5 years
> old now, it was released in December 2007 (not that you could fix that, I do
> realize).
Yup I know, and no I can't. The next Debian release will have perl 5.14.2.
> A regular EPICS installation can cope with multiple Perl versions, you just
> have to rebuild in the src/cap5 directory with PATH set to pick up each Perl
> version; copies of libCap5.so will then be installed into the appropriate
> directories and can coexist.
Good to know.
- epics-perl & perlapi-5.10.1 Martin Konrad
- Re: epics-perl & perlapi-5.10.1 Michael Davidsaver
- Re: epics-perl & perlapi-5.10.1 Andrew Johnson
TDS3054B oscilloscope alternatives Brown, Garth
<2013>
2025
2026
Trio Motion support for Motor Record Miroslav Pavleski
<2013>
2025
2026
