For any driver/device sopport I have used ao only allows one value.
If there is a string record you can put that together into one
and send it, but the first things to come to my mind are gensub
and asub, each of which you can use as soft records and then
output the string to the device (if there is an asyn string
record which I don't know because I have never used asyn)
Hope this helps?
Maren
On Thu, 14 Mar 2013, Vikram Bhagat wrote:
I am using ao.
__________________________________________________________________________________________________________________________
To: Vikram Bhagat <[email protected]>
Cc: Mark Rivers <[email protected]>; "[email protected] " <[email protected]>
Sent: Thursday, March 14, 2013 9:52 AM
Subject: Re: asynInt32 pass 2 value
Vikram,
I've never used asyn, but is there a string record that you could put both
into via a gensub or asub? - I take it the device knows to take two
input values?
Aloha,
Maren
> Yes, you are right. But slightly different. User have to set the V & I. EPICS device support takes these values and need
> to pass both value to linux driver to set power.
> Linux driver takes 2 value so we have to set both value we cant set single value.
> as you suggest way to take 2 PVs how i can combine both in the asyn driver ? if by some way it is possible in asyn
driver
> can combine it then my problem solve.
> Thanks Mark
_
> From: Mark Rivers <[email protected]>
> To: 'Vbhagat' <[email protected]>; "[email protected] " <[email protected]>
> Sent: Wednesday, March 13, 2013 9:35 PM
> Subject: RE: asynInt32 pass 2 value
> What I am asking is what are the two values used for? Are they for 2 different parameters, for example one controls the
> voltage and the controls the current on a power supply. Or are you trying to send 2 successive values of the voltage?
> If they are 2 different parameters then you should be using the drvUser interface to pass that information from device
> support to the driver.
> For example one record might be:
> record(ao, ?Current?) {
> field(DTYP, ?asynInt32?)
> field(OUT, ?@asyn($(PORT),0,0)CURRENT)
> record(ao, ?Voltage?) {
> field(OUT, ?@asyn($(PORT),0,0)VOLTAGE)
> The asyn driver will take the drvUser strings ?CURRENT? and ?VOLTAGE? and parse them. Typically it will set the
pasynUser->reason
> field of the device support pasynUser as a flag to indicate what parameter this record is associated with.
> If this is the type of thing you are trying to do then you should not be trying to send two values over the asynInt32
> interface at the same time (which is not possible). You send them separately, with the pasynUser->reason flag that
> indicates which parameter is being sent.
> Mark
> From: Vbhagat [mailto:[email protected]]
> Sent: Wednesday, March 13, 2013 3:12 PM
> To: Mark Rivers; [email protected]
> Actually i want to pass 2 value & driver do process on both. I think asyIntt32Array can use , but specifically. I don't
> know how to use it.
> With regard
> Sent from Samsung Mobile
> Mark Rivers <[email protected]> wrote:
> What do you want to do with the two values? Have the driver process one and then the other soon after? Why do you want
> to send 2 values?
> Mark
> From: [email protected] [[email protected]] on behalf of Vikram Bhagat [[email protected]]
> Sent: Wednesday, March 13, 2013 4:51 AM
> To: [email protected]
> Subject: asynInt32 pass 2 value
> Hi all,
> Is there any way to pass 2 values for asynInt32 PVs ?
> for example
> $$ caput PVNAME 255 254
> and record pass these 2 values to device support for processing.
> or by any othere DTYP have such facility.....
> Thanks
- RE: asynInt32 pass 2 value Vbhagat
- RE: asynInt32 pass 2 value Mark Rivers
- Re: asynInt32 pass 2 value Vikram Bhagat
- Re: asynInt32 pass 2 value Maren Purves
Training 2013 Yasemin Barutçu
<2013>
2025
2026
RE: asynInt32 pass 2 value ian.gillingham
<2013>
2025
2026
