1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: asynInt32 pass 2 value
To: Vikram Bhagat <[email protected]>, "[email protected] " <[email protected]>
Date: Thu, 14 Mar 2013 12:48:16 +0000
You can definitely combine them in the asyn driver.  There are lots of examples.  In asyn there is a test application called testAsynPortDriver, which is a simple simulation of a digital oscilloscope.  The driver is written using the C++ asynPortDriver base class.  It combines several ao, bo and mbbo records.
Sent: Thursday, March 14, 2013 3:30 AM
To: Mark Rivers; [email protected]
Subject: Re: asynInt32 pass 2 value
Yes, you are right. But slightly different. User have to set the V & I. EPICS device support takes these values and need to pass both value to linux driver to set power.
Linux driver takes 2 value so we have to set both value we cant set single value.
as you suggest way to take 2 PVs how i can combine both in the asyn driver ? if by some way it is possible in asyn driver can combine it then my problem solve.
Thanks  Mark
To: 'Vbhagat' <[email protected]>; "[email protected] " <[email protected]>
Sent: Wednesday, March 13, 2013 9:35 PM
What I am asking is what are the two values used for?  Are they for 2 different parameters, for example one controls the voltage and the controls the current on a power supply.  Or are you trying to send 2 successive values of the voltage?
If they are 2 different parameters then you should be using the drvUser interface to pass that information from device support to the driver.
For example one record might be:
record(ao, “Current”) {
  field(DTYP, “asynInt32”)
  field(OUT, “@asyn($(PORT),0,0)CURRENT)
record(ao, “Voltage”) {
  field(OUT, “@asyn($(PORT),0,0)VOLTAGE)
The asyn driver will take the drvUser strings “CURRENT” and “VOLTAGE” and parse them.  Typically it will set the pasynUser->reason field of the device support pasynUser as a flag to indicate what parameter this record is associated with.
If this is the type of thing you are trying to do then you should not be trying to send two values over the asynInt32 interface at the same time (which is not possible).  You send them separately, with the pasynUser->reason flag that indicates which parameter is being sent.
From: Vbhagat [mailto:[email protected]<mailto:[email protected]>]
Sent: Wednesday, March 13, 2013 3:12 PM
To: Mark Rivers; [email protected]<mailto:[email protected]>
Actually i want to pass 2 value & driver do process on both.  I think asyIntt32Array can use , but specifically. I don't know how to use it.
With regard
Sent from Samsung Mobile
Mark Rivers <[email protected]<mailto:[email protected]>> wrote:
What do you want to do with the two values?  Have the driver process one and then the other soon after?  Why do you want to send 2 values?
From: [email protected]<mailto:[email protected]> [[email protected]<mailto:[email protected]>] on behalf of Vikram Bhagat [[email protected]<mailto:[email protected]>]
Sent: Wednesday, March 13, 2013 4:51 AM
To: [email protected]<mailto:[email protected]>
Subject: asynInt32 pass 2 value
Hi all,
     Is there any way to pass 2 values for asynInt32 PVs ?
for example
$$ caput PVNAME 255 254
and record pass these 2 values to device support for processing.
or by any othere DTYP  have such facility.....
Thanks
RE: asynInt32 pass 2 value Vbhagat
RE: asynInt32 pass 2 value Mark Rivers
Re: asynInt32 pass 2 value Vikram Bhagat
Prev: RE: asynInt32 pass 2 value Mark Rivers
Next: RE: mbboDirect record questions Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Example app won't run on cygwin James F Ross
