1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: mbboDirect record questions
Date: Fri, 15 Mar 2013 11:34:26 -0500 (CDT)
Hi Mark,
On Mar 14, 2013, at 7:23 PM, Mark Rivers <[email protected]> wrote:
> But I think the way the mbboDirect record works it expects the Bn fields to be the ones you initialize before the record first processes.  I don't know how that is supposed to work if your driver does not provide an initial value, and the database does not know how to define it.  Because the first time you do a caput to B1, it will also write the values of B2, B3, etc. which may not have been initialized correctly yet.
> Maybe I'm missing something?
Probably not, IIRC the mbb*direct record types were not written by the EPICS core developers but by someone (I think at JLab) hacking on the mbb* records until they got something that did what they wanted without thinking about other users or uses for them. The documentation is similarly lacking and broken on the Wiki page.
In December I made some major cleanups in the code and how these records behave for the versions on the 3.15 branch, but I couldn't bring those changes back to the 3.14 branch because they would almost certainly break existing databases. For 3.14 users I recommend only using these record types for their behavior of splitting a number into individual bits or the reverse.
- Andrew
Sent from my iPad
Re: mbboDirect record questions Vishnu Patel
RE: mbboDirect record questions Mark Rivers
Prev: Re: EPICS CSS JAAS Authentication with LDAP Kasemir, Kay
Next: Re: Breakpoint tables status and usage in EPICS Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: mbboDirect record questions Mark Rivers
Next: Re: mbboDirect record questions Vishnu Patel
