1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Breakpoint tables status and usage in EPICS
Date: Mon, 18 Mar 2013 08:09:25 +0000
Hi Andrew
Thanks for your feedback.
http://www-csr.bessy.de/control/SoftDist/csm/cvtRecord.html : cvt is good but does not work for waveform…
Lana
Sent: 15 March 2013 18:00
To: Abadie Lana
Cc: [email protected]
Subject: Re: Breakpoint tables status and usage in EPICS
Hi Lana,
On Mar 15, 2013, at 6:04 AM, Abadie Lana <[email protected]> wrote:
1.       Can we reload EPICS breakpoint table dynamically without restarting IOCs? (if yes how? Some pointers to wiki would be helpful). I found some messages in TechTalk that it is possible but then I see this bug https://blueprints.launchpad.net/epics-base/+spec/breakpoint-tables in launchpad. So i’m confused…
It is apparently possible, but not an officially supported practice. I believe BESSY-2 do this, so Ralph should be able to help you with how they actually do it.
The blueprint that you found was something I wrote to try and get that ability included officially, but so far it hasn't gone any further than those ideas. The complication that is hinted at in the blueprint is that the records hold a pointer to the actual breakpoint table in memory if they are using one, but there is no locking or other way to communicate with the individual record instances if the table gets modified or replaced.
2.      In general, how do you use breakpoint tables. The native one from EPICS? Or did you implement your own record types? I’m aware of one from Bessy (cvt) which looks very interesting.
The built in support routines are available to any record type, but are currently only used by the ai and ao record types in Base. They could also be used by subroutine record code.
3.      How did you handle breakpoint tables with waveform record type? Via subroutines?
That would have to be done manually (i.e. with subroutines or aSub records) at the moment unless you write your own record type to do it.
4.      In our cases, we are both interesting by having mapping tables and functions.
That would be an obviously useful thing to implement if someone hasn't already done it (what does the cvt record do?).
- Andrew
Sent from my iPad
Breakpoint tables status and usage in EPICS Abadie Lana
Re: Breakpoint tables status and usage in EPICS Andrew Johnson
Prev: Spring 2013 EPICS Collaboration Meeting ian.gillingham
Next: Re: mbboDirect record questions Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Breakpoint tables status and usage in EPICS Andrew Johnson
Next: RE: Breakpoint tables status and usage in EPICS Andrew C. Starritt
