1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Epics Lecture videos are broken!
To: [email protected]
Date: Wed, 20 Mar 2013 08:58:21 +0100
FWIW: I was able to see the videos from here (PSI, Switzerland). There
are a few broken links (images, etc.) when you go to the lecture pages and
follow the links from there, but the actual content is fine.
I tried only a few of them, so it can be that there are some that do not work, but at
least it does not seem to be a general problem.
BTW, my movie player (totem, on Ubuntu Linux) played the videos without problems
(I did not need RealPlayer.)
best regards,
Timo
On 03/19/2013 08:44 PM, Andrew Johnson wrote:
Hi Yasemin,
On 2013-03-18 Yasemin Barutçu wrote:
When I tried to play the clips
  (http://www.aps.anl.gov/epics/docs/GSWE.php), I got following error.
"Requested file not found.
The link you followed may be outdated or inaccurate."
Can you send me a specific URL that fails and gives you the above error?
Which videos have you tried?
I was able to watch a few of the GSWE videos from here inside the APS but I
haven't checked them all, so it may be that some specific ones you're trying
are failing, or that there's a more general problem with displaying any of
them through our firewall.
- Andrew
Timo Korhonen  PSI (Paul Scherrer Institut, http://www.psi.ch)
               CH-5232 Villigen PSI
               tel + 41- 56 3103262  fax + 41 - 56 310 5090
e-mail:	       [email protected]
Epics Lecture videos are broken! Yasemin Barutçu
Re: Epics Lecture videos are broken! Andrew Johnson
Prev: RE: Breakpoint tables status and usage in EPICS Andrew C. Starritt
Next: Re: SNMP device support John A. Priller
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Epics Lecture videos are broken! Andrew Johnson
Next: Spring 2013 EPICS Collaboration Meeting ian.gillingham
