Am Donnerstag, 21. März 2013, 21:46:31 schrieb Eric Norum:
> Now I read the original article more closely.
> Tim's suggestion is a lot better…..
Your (Eric) solution should work reliably, too, if you are using a recent
release of version 2.1 of the sequencer and enable the safe mode (+s) option.
Safe mode guarantees that the value of 'bin' does not change asynchronously
after evaluation of the when-conditions has been triggered, until the state-
change action block finishes. If we get another event that resets the value to
bin=0, the state set does not see this new value until the next time when-
conditions are evaluated.
Indeed, this is one of the problems that safe mode was designed to solve.
BTW, it is possible to increase the pulse length of a transient signal in the
database using a seq+bo record. The following database demonstrates the
technique:
record(calcout,"timebase") {
field(INPA,"timebase")
field(CALC,"!A")
field(SCAN,"2 second")
field(OUT,"transientPulse PP")
record(bo,"transientPulse") {
field(HIGH,"0.1")
record(seq,"triggerPulse") {
field(DOL1,"transientPulse CPP")
field(LNK1,"oneSecondPulse PP")
field(DLY2,"1.0")
field(DOL2,"0")
field(LNK2,"oneSecondPulse PP")
record(bo,"oneSecondPulse") {
Cheers
Ben
> On Mar 21, 2013, at 1:43 PM, Eric Norum <[email protected]> wrote:
> > How about the following?
> > int bin; assign bin to "abc:bin"; monitor bin;
> > ss ttt {
> > state isZero {
> > when(bin == 1) {
> > printf("Received a trigger!!\n");
> > } state isOne
> > state isOne {
> > when(bin == 0) { } state isZero
> > On Mar 21, 2013, at 10:04 AM, Tim Mooney <[email protected]> wrote:
> >> Hi Song,
> >> I have not done this myself in SNL, but if I needed to do it, I'd start
> >> by looking into the "syncq" and "pvGetQ" commands in the SNL Reference
> >> Manual:
> >> http://www-csr.bessy.de/control/SoftDist/sequencer/Reference.html
> >> Tim
> >> ----- Original Message -----
> >>> From: "Song Hu" <[email protected]>
> >>> To: [email protected]
> >>> Sent: Thursday, March 21, 2013 10:58:28 AM
> >>> Subject: how to trigger on positive edge only with snl
> >>> Hi,
> >>> I would like to trigger some actions when a binary PV changes from 0
> >>> to 1. No action should be taken when it changes from 1 to 0. I made
> >>> some code like:
> >>> monitor bin;
> >>> evflag binFlag;
sync
> >>> bin binFlag;
> >>> ss ttt
> >>> state testState
> >>> when(efTestAndClear(binFlag)&&(bin == 1))
> >>> }state testState
> >>> When abc:bin changes from 0 to 1 and then quickly go back to 0, it is
> >>> not working every time.
> >>> What is the appropriate way to implement such positive edge only
> >>> trigger?
> >>> Thanks in advance for your help.
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
- Re: how to trigger on positive edge only with snl Tim Mooney
- Re: how to trigger on positive edge only with snl Eric Norum
eclipse --launcher.openFile problem on multi-user Linux Michael Davidsaver
<2013>
2025
2026
RE: how to trigger on positive edge only with snl Allison, Stephanie
<2013>
2025
2026
