1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: MEDM objects turn white when ioc running correctly
To: 张德敏 <[email protected]>, tech-talk <[email protected]>
Date: Mon, 25 Mar 2013 11:13:50 +0000
Does the command "caget" from EPICS base work to read the value of the PVs on the same computer running medm?
If not, then your problem may be a firewall.  Make sure "iptables" is either disabled or configured to allow TCP and UDP on ports 5064 and 5065.
From: [email protected] [[email protected]] on behalf of 张德敏 [[email protected]]
Sent: Monday, March 25, 2013 4:24 AM
To: tech-talk
Subject: MEDM objects turn white when ioc running correctly
I have built a softIOC on my Linux rhel5(base3.14.9-prel,ASYN4-8,Stream Device-2-3). When running the application, it works well(using "dbpf" can set channel value, and the device can get the setting). But when executing MEDM, the objects turn white. It is very strange(the control channel of object in MEDM and the record in db file have the same name ).
MEDM objects turn white when ioc running correctly 张德敏
Prev: MAXV card with firmware version 1.42 austen.rose
Next: PMAC Gaudiello, Phillip
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: MEDM objects turn white when ioc running correctly 张德敏
Next: FW: MEDM objects turn white when ioc running correctly Hill, Jeff
