I am new to synApps and use of scaler/counters, etc. and I have some
questions regarding the use and capabilities of the SIS3820 VME
scaler and its driver.
Our current setup for the project I am working on is a VME crate
with an Emerson MVME3100 CPU board, an SIS3820 scaler, and a Hytec
VDD2670 DAC. Don't know at the moment how much memory the CPU card
has, or if the memory card on the 3820 is larger than 64M. The CPU
is running RTEMS rather than VxWorks.
The use of this setup is currently a fairly straightforward scan
(using sscan records) where the DAC output is ramped over a range of
values, and a new count captured at the end of each acquisition
period (dwell time) during which the DAC output is stable. The
dwell time is currently hundreds of milliseconds, so nothing that
even comes close to the limits of the scaler card.
But the next step is to support the following scenario:
- An external pulse indicates when to start counting the number
of events on a single channel. This pulse will repeat about
every 10ms (100 Hz)
- For each external pulse, begin counting event pulses on the
one channel. At regular intervals, capture the current counter
value (doesn't matter if it is reset at the start of each
period, although I am guessing that NOT resetting it is probably
safer, as it would be less likely to miss an event close to the
start of the next interval).
- Continue this for a specified number of the regular intervals,
then stop capturing the counter value until the next external
pulse
Basically there will be an external pulse once every 10ms that
indicates the start of a 1ms long period of interest. During that
1ms period, we need to capture the state of the counter as often as
possible (minimum dwell time), but at regular intervals.
The original specs called for the dwell time to be 20ns, but after
looking over the specs on the 3820, it seems that is not possible.
So here are my questions:
- What IS the minimum dwell time for counting on a single
channel? The smallest one indicated in the documentation says
220ns for 8 channels (using 8-bit counts, which - as the doco
points out - is more than large enough for such short dwell
times). Can this be made even smaller when we really only need
to count 1 channel? Or maybe 2, if we needed to also count
50MHz pulses on channel 1 to use as a time reference?
- The minimum dwell times for the "Histogramming Scaler mode
(MCS with add enabled)" are longer than those for the MCS mode
with the same number of channels and counter depth. Why is
that? Is it really doing an addition operation that is taking
up time? I would have thought that the Histogram mode would be
the same as the MCS mode except that you do NOT take the time to
clear the counts (expect prior to the first scan). And to guard
against incrementing the counts between scans, simply disabling
the inputs or counting of them would do the job. So unless
disabling the counting between scans takes a lot longer than
clearing them at the start of each scan, I would think that the
Histogram mode would have the same or shorter dwell times than
MCS mode, not LONGER! Why is it the other way around?
- Is it possible to get at least the 220ns dwell time
performance using the existing driver, or would I have to modify
it?
- If modification is not needed, how do I get it do do the MCS
mode with 8-bit counts and the 220ns dwell time?
- If I modified the driver, could I get even smaller dwell times
(without changing the firmware/FPGA programming)?
- Can someone explain the LNE (Load Next Event) concept?
Depending the context it is used in, it seems that sometimes it
means to advance which channel's count is being incremented, and
other times it seems to mean copy the counts to the FIFO. Is
either of these correct? Does it mean something different for
different modes? When does it apply and when does it not?
Probably more questions as I dig in to this some more, but any
pointers, explanations, insights, suggestions, etc would be much
appreciated.
Mark Davis
NSCL, MIchigan State University
- RE: SIS3820 scaler limits Mark Rivers
Arcnet question James F Ross
<2013>
2025
2026
<2013>
2025
2026
ANJ, 20 Apr 2015 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
