Hello,
I'm unable to build caQtDM for Ubuntu using the 2.8.0 sources.
The following output is generated by running the caQtDM_Build script:
=========== remove binaries from directory =============
========== remove makefiles from directories ============
=========== clean all ==================
Cannot find file: all.pro.
make: *** No rule to make target `distclean'. Stop.
============ make all =================
./caQtDM_Build: line 28: dye: command not found
=========== build plugins =============
./caQtDM_Build: line 32: linuxbuild: command not found
=========== do not forget to copy plugins /Qt-4.8.2/plugins/designer/
Is the file "all.pro" missing from the 2.8.0 sources?
Where does the "dye" command come from?
Thanks!
Jason
RE: SIS3820 scaler limits Mark Rivers
EPICS Qt Framework SVN repository Ricardo Fernandes
<2013>
2025
2026
EPICS device driver support for Tektronix AFG3000C Tang, Johnny Y.
<2013>
2025
2026
