1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Newport Piezo USB Controllers
To: Andrew Gomella <[email protected]>, "[email protected]" <[email protected]>
Date: Sun, 7 Apr 2013 15:03:10 +0000
Hi Andrew,
This has been on my to-do list for some time now.  I have an Agilis controller and actuator that Newport sent me because they would like to have an EPICS driver.
I believe that by installing the "Agilis User Tool" software on Windows then one can send the ASCII commands over a COM port.  The drvAsynSerialPort driver on Windows should then be able to communicate.
If you don't have that software you can get it here:
ftp://download.newport.com/MotionControl/Current/MotionControllers/Agilis/Software/
I have not tried connecting it to a Linux system to see if a device like /dev/ttyUSB0 appears, but if it does then one should be able to use it on Linux as well.
I will try to play with it this week.
From: [email protected] [[email protected]] on behalf of Andrew Gomella [[email protected]]
Sent: Saturday, April 06, 2013 10:46 AM
To: [email protected]
Subject: Newport Piezo USB Controllers
Has anyone had any luck using Newport Agilis Controllers (USB) with EPICS?
http://www.newport.com/Agilis-Motion-Controllers/848283/1033/info.aspx
Newport only included LabView and Windows DLL's, but I'm really hoping to control them directly through our EPICS system. They run off of ASCII commands which are detailed in the user manual.
I guess using CA Lab is an option, but was hoping to remove LabView entirely from the setup.
Andrew
RE: Newport Piezo USB Controllers Mark Rivers
Newport Piezo USB Controllers Andrew Gomella
Prev: Newport Piezo USB Controllers Andrew Gomella
Next: Is there suitable "accelerator" logbook for experiments? Andrei Liyu
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Newport Piezo USB Controllers Mark Rivers
