1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Stream Device and Asyn
To: Alan Greer <[email protected]>
Date: Mon, 8 Apr 2013 15:35:02 +0000
I can't think of any reason why it would be doing a read.  asyn device support does attempt a read at iocInit on many output records, but not on stringout records.
Could this be from a "flush" operation?  Your driver is printing the message "device read"?
Sent: Monday, April 08, 2013 9:42 AM
To: Mark Rivers
Cc: [email protected]
Subject: Re: Stream Device and Asyn
Hi sure, here it is:
record(stringout, "T1:STRING")
     field (DTYP, "stream")
     field (OUT,  "@test.proto stringIO SSH1")
I should say that originally I was attempting to write the contents of
the string record to the device, instead of the hard coded string
"cpu\n".  I changed it to the hard coded value when I couldn't get the
original setup to work.
Kind regards, Alan
On 04/08/2013 03:36 PM, Mark Rivers wrote:
> Can you send the database you are using that invokes that protocol file?
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On Behalf Of Alan Greer
> Sent: Monday, April 08, 2013 9:17 AM
> To: [email protected]
> Subject: Stream Device and Asyn
> Hi all,
> I have an Asyn driver (SSH) that I'm attempting to use with Stream Device.
> My setup
> EPICS_BASE=/home/epics/R3.14.12.2/base
> ASYN=/home/epics/R3.14.12.2/asyn4-18
> STREAM=/home/epics/R3.14.12.2/stream2-6
> Here is my protocol file
>   >>  more test.proto
> stringIO {
>     out "cpu\n";
> When I process the record that executes the stringIO routine I get the
> following IOC output (with asyn trace set)
> epics>  2013/04/08 15:03:39.859 SSH1 addr -1 queueRequest priority 0 not
> lockHolder
> 2013/04/08 15:03:39.859 SSH1 schedule queueRequest timeout
> 2013/04/08 15:03:39.859 asynManager::portThread port=SSH1 callback
> 2013/04/08 15:03:39.859 SSH1 addr -1 queueRequest priority 0 not lockHolder
> 2013/04/08 15:03:39.859 device read.
> 2013/04/08 15:03:39.859 Close device connection (fd -1221589168): Read error
> 2013/04/08 15:03:39.859 Open connection to device  reason:0
> 2013/04/08 15:03:40.346 Opened connection to device
> 2013/04/08 15:03:40.347 Close device connection (fd -1221589168): Read error
> 2013/04/08 15:03:40.347 device read.
> When I look at those messages I agree that the device read will return a
> read error, as there is nothing to read back.  What I don't understand
> is why readIt is called at all.  I was expecting the protocol function
> to only call into writeIt.  What I see is that readIt appears to be
> called with a timeout of 0.  Can anyone help me with this?  My asyn
> driver is (loosely) based on the  drvAsynIPPort driver, with an
> additional library in place of the actual socket calls made, and
> simplified as much as possible.
> The output messages continue indefinitely when I process the record,
> disconnecting, reconnecting, attempt a read... etc.
> I have successfully used the driver with a custom asyn motor record
> device support layer, and so the driver is functional (at least to some
> extent!)
> Any help or suggestions would be appreciated.
> Kind regards, Alan Greer
Re: Stream Device and Asyn Alan Greer
RE: Stream Device and Asyn Mark Rivers
Prev: Re: Stream Device and Asyn Alan Greer
Next: Re: Stream Device and Asyn Alan Greer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
