1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: macLib: macro PORT is undefined
To: Yasemin Barutçu <[email protected]>
Date: Wed, 10 Apr 2013 09:30:57 +0100
Dear Yasemin,
In your start-up script it appears you have defined Port=L0 but the record wants it in capital letters.
So your dbLoadRecords should be
dbLoadRecords("/opt/epics/modules/soft/asyn4-20/db/asynRecord.db","P=yasemin:,R=asyn,PORT=L0,ADDR=24,IMAX=100,OMAX=100")
Give this a try.
Kind regards, Alan
On 04/10/2013 08:56 AM, Yasemin Barutçu wrote:
Hello,
I have a problem when start ioc.
O.S. : Scientific Linux
Base Vers : 3.14.12.3
I've been gettin following error when I start IOC.
cd /opt/Epics-Ex/burakCihaz
dbLoadDatabase "dbd/burakCihaz.dbd"
burakCihaz_registerRecordDeviceDriver pdbbase
##Configure devices
drvAsynSerialPortConfigure("L0","/dev/ttyS0",0,0,0)
asynSetOption("L0",-1,"baud","9600")
asynSetOption("L0",-1,"bits","8")
asynSetOption("L0",-1,"parity","none")
asynSetOption("L0",-1,"stop","1")
asynSetOption("L0",-1,"clocal","Y")
asynSetOption("L0",-1,"crtscts","N")
dbLoadRecords("/opt/epics/modules/soft/asyn4-20/db/asynRecord.db","P=yasemin:,R=asyn,Port=L0,ADDR=24,IMAX=100,OMAX=100")
macLib: macro PORT is undefined (expanding string field(PORT,"$(PORT)")
filename="../dbLexRoutines.c" line number=319
macExpandString failed for file /opt/epics/modules/soft/asyn4-20/db/asynRecord.db
yasemin:asyn.PORT Has unexpanded macro
Can't set "yasemin:asyn.PORT" to "$(PORT,undefined)"
Error at or before ")" in file "/opt/epics/modules/soft/asyn4-20/db/asynRecord.db" line 4
## Load record instances
#dbLoadRecords("db/xxx.db","user=rootHost")
cd /opt/Epics-Ex/burakCihaz/iocBoot/iocburakCihaz
iocInit
Starting iocInit
## EPICS R3.14.12.3 $Date: Mon 2012-12-17 14:11:47 -0600$
## EPICS Base built Mar 28 2013
## Start any sequence programs
#seq sncxxx,"user=rootHost"
epics> ^C
[root@localhost iocburakCihaz]# vi st.cmd
[root@localhost iocburakCihaz]# ../../bin/linux-x86_64/burakCihaz st.cmd
#!../../bin/linux-x86_64/burakCihaz
## You may have to change burakCihaz to something else
## everywhere it appears in this file
< envPaths
epicsEnvSet("ARCH","linux-x86_64")
epicsEnvSet("IOC","iocburakCihaz")
epicsEnvSet("TOP","/opt/Epics-Ex/burakCihaz")
epicsEnvSet("EPICS_BASE","/opt/epics/base-3.14.12.3")
epicsEnvSet("ASYN","/opt/epics/modules/soft/asyn4-20")
##Configure devices
iocInit
Starting iocInit
epics>
macLib: macro PORT is undefined Yasemin Barutçu
Prev: Conversion problem from double to 32 bit unsigned int (in ao) Dirk Zimoch
Next: Re: Stream Device and Asyn Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: macLib: macro PORT is undefined nick.rees
Next: Conversion problem from double to 32 bit unsigned int (in ao) Dirk Zimoch
