1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: linux file search from Asyn
To: <[email protected]>
Cc: [email protected]
Date: Wed, 10 Apr 2013 10:32:55 +0000
Hi Vishnu,
Hi Vishnu,
It sounds like you need an asynPortDriver driver that has a writeOctet method that basically calls system(“string”) or execl( “path”, “arg”, ... ) and catches the response from stdout in the readOctet method. I don’t think such a beast exists but if you took the asynPortDriver documentation (http://www.aps.anl.gov/epics/modules/soft/asyn/R4-21/asynPortDriver.html) and the example I don’t think it would take long to write. You could then use StreamDevice or an asyn record to work out what to do with the reply.
I am posting this to techtalk in case anyone has done this as an exercise and not published it yet.
Cheers,
Nick Rees
Principal Software Engineer           Phone: +44 (0)1235-778430
Diamond Light Source                  Fax:   +44 (0)1235-446713
Sent: 10 April 2013 10:24
To: Rees, Nick (DLSLtd,RAL,DIA)
Subject: Re: linux file search from Asyn
Hi Nick,
      Actually i want to develop asyn based device support, so that EPICS PV have status of particular board is present or not in the system.
In my linux layer for each board one file is generated in /dev/XXX     at boot time.
so if i can read the XXX file is present or not in /dev directory,  EPICS PV can display the status of perticular board.
Thanks
With regards
Vishnu
Sent: Wed, 10 Apr 2013 13:48:48
To: <[email protected]>, <[email protected]>
HI Vishnu,
You have to provide more information about what you want to do. Do you want to somehow implement an asyn support layer that implements a search (which I don't really understand) or do you just want to find where the asyn support code is in your file system. If the latter, the asyn device support file are in the asyn/devEpics directory of the asyn support module.
Cheers,
Nick Rees
From: [email protected] [mailto:[email protected]] On Behalf Of Vishnu Patel
Sent: 10 April 2013 08:26
To: techtalk
Subject: linux file search from Asyn
Dear all,
          I want to search specific linux file in ayn Device support layer. how is it possible?
Thanks
Get your own FREE website and domain with business email solutions, click here
Image removed by sender.
Prev: Re: Stream Device and Asyn Dirk Zimoch
Next: Re: linux file search from Asyn Vishnu Patel
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Conversion problem from double to 32 bit unsigned int (in ao) Benjamin Franksen
Next: RE: linux file search from Asyn Mark Rivers
