1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: devIocStats
To: <[email protected]>
Date: Sat, 13 Apr 2013 14:42:07 +0200
Hi People
we have recently discovered some bugs in devIocStats in the vxWorks
implementation that measures the cpu load, which result in wrong results to be
displayed. I hacked away at the problem for some days and ended up with a
complete re-write. The solution considerably reduces code size and complexity,
is therefore much easier to understand and maintain, and --most importantly--
works correctly. It also contains some additional features:
* A test procedure that measures how well the initial calibration works by
doing it for a number of times and gathering statistics (min, max, avg). This
was useful to determine how long initial calibration should run (the default
is 30 clock ticks which on a mv2100 gives me a variation of less than 0.4%).
* Another test procedure (to be called from the shell) adds exactly 50% load
to the IOC (it burns cpu for one clock tick, then sleeps for one, and repeats
that in a loop for the given duration), so one can see whether the measured
cpu load increases appropriately (it does on my test machines).
* Experienced users can customize behaviour to a certain extent by changing
the values of some global variables.
One downside is that I have tested only with a pretty old version of vxWorks
(5.4.2, we do not have any more recent one here) and with mv162 and mv2100
boards. I would like to ask anyone interested whether they would be willing to
test my code with newer vxWorks versions and other hardware. I don't expect
problems but I would feel safer...
Who is currently maintaining devIocStats and how do I submit patches?
Cheers
Ben Franksen
()  ascii ribbon campaign - against html e-mail
/\  www.asciiribbon.org   - against proprietary attachments
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
RE: devIocStats Allison, Stephanie
Prev: Re: rdb archiver and eclipse help Kasemir, Kay
Next: sequencer and c-code Pierrick Hanlet
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: devIocStats Allison, Stephanie
