1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: sequencer and c-code
To: Pierrick Hanlet <[email protected]>
Cc: Tech Talk <[email protected]>
Date: Mon, 15 Apr 2013 09:16:39 -0400 (EDT)
To: "Tech Talk" <[email protected]>
Sent: Saturday, April 13, 2013 1:38:29 PM
Subject: sequencer and c-code
Hi all,
I'm developing a state machine for a string of superconducting magnets. I'm reading from an
external configuration database (cdb) to pick up fields (alarm, adel, scan, etc) for each of my
PVs as well as the state transition parameters. At present, on each entry block of each state, I
call my c-function to read from the cdb and fill a global struct with the field values for each PV.
Since the list may change in each state, I have arrays for each field.  For example:
PV.name[ndx] and PV.hihi[ndx] which I fill for each state and these are global in a header file.
I also have, in another header file, all of my assignments:
e.g.  SS2cx01[4] is assigned to MICE-SS2-CX-01:RDGK.HIHI in a header file.
What I want to do is to have another c-function, SetPVFields(),  which invokes seq_pvPut().  Since I
call SetPVFields(ssId,State,ndx) in a loop over ndx in my .st file, I want to be able to relate PV.name[ndx]
with pvIndex() inside of my SetPVFields() function.  Is there a way to do this?  One thought that I had is
to create the relationship array between pvIndex and the PV name in the global entry block and use
it inside of SetPVFields(), but I'm not sure of the details and this does not strike me as very elegant.
Pierrick
Hey Pierrick,
Sorry I didn't get back to you Friday.  After looking over your code the only thing I think you're missing for seq_pvPut() is the Id for the PV.  So I think you're right in that if you create an additional array to hold the values from pvIndex, your c should work.
However, I tend to agree with Ben's comments.  Doing this in python as a CA client may be an easier way to go.  Especially as it may evolve over time.
I can take a look at it again if you've updated the code.  Just write me offline.
Wesley
sequencer and c-code Pierrick Hanlet
Prev: RE: Problem in installing asyn4-19 in mint13 system Mark Rivers
Next: Re: Problem in installing asyn4-19 in mint13 system Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: sequencer and c-code Benjamin Franksen
Next: Problem in installing asyn4-19 in mint13 system Priyabrata Jenamani
