1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: sscan/ saveData problem with RW permission, and not an NFS issue
To: Vesna Samardzic-Boban <[email protected]>
Cc: [email protected]
Date: Tue, 16 Apr 2013 10:18:26 -0500 (CDT)
Hi Vesna,
Thanks for the information.  I haven't tested sscan on vxWorks 6.9, though
I'm told it works on vxWorks 6.8.  I don't think creat() uses O_RDRW as a
file-permission mask, and I don't understand why open() would work while
creat() does not.  I'm ok with making this change, but I'd like to understand
it better first.
Tim
----- Original Message -----
> From: "Vesna Samardzic-Boban" <[email protected]>
> To: [email protected]
> Sent: Monday, April 15, 2013 8:52:30 PM
> Subject: sscan/ saveData problem with RW permission, and not an NFS issue
> Hi All,
> Found a problem as follows:
> Running a scan record on a vxWorks IOC and when entering 'File
> system' in scan_saveData.adl screen, an error message in the 'Save
> status' field follows:
> "RW permission denied !!!"
> At first I suspected NFS but after checking it found that my problem
> was in the sscan's saveData.c and/or VxWorks is 6.9
> Tried two versions of sscan, 2-6-6 and 2-8-2, they gave the same
> result as above. These two versions are same regarding the
> saveData.c and its function
>     checkRWpermission(char* path)
> and specifically the line
>     file= creat(tmpfile, O_RDWR);
> that creates test file "rix_" with file permissions 002 (because
> O_RDRW = 2)
> (O_RDRW is flag "Open for reading and writing" or File Access
> Options)
> The file permissions 002 become
> -------w-  in   terms of    rwxrwxrwx
> and hence the error "RW permission denied !!!"
> Found a solution by using vxWorks function open() instead of creat().
> open() - opens a file and optionally creates a file if it does not
> exist.
> open() - also offers a parameter for "mode" i.e. file permissions,
> which i set to 0x666 in the example below
>      file = open (tmpfile, O_CREAT | O_RDWR, 0666);
> Then scan data can be saved as expected.
> BTW
> saveData.c uses open() for creating 'subdirectory'.
>           fd = open (local_pathname, O_RDWR | O_CREAT,
>                            FSTAT_DIR | DEFAULT_DIR_PERM | 0775);
> Has anyone had similar problems ?
> Is this an sscan/saveData.c issue or vxWorks 6.9 issue (I do not have
> any other version of vxWorks) ?
> How about sscan/saveData on OS's other than vxWorks?
> Thanks Vesna
> P.S.
> In my vxWorks 6.9 and its ioLib.c, creat() does not offer file
> permissions (set to 0 as below):
> int creat
>     const char *name,           /* name of the file to create */
>     int         flag            /* file permissions */
>     return (ioCreateOrOpen (name, flag, 0, TRUE));
> SUPPLIERS: As of 1 January 2013, the Australian Synchrotron Company
> Ltd has changed its business name. However, the trading name will
> remain Australian Synchrotron.
> Please address all quotations and invoices to: Synchrotron Light
> Source Australia Pty Ltd (SLSA), ABN: 18 159 468 256
Re: sscan/ saveData problem with RW permission, and not an NFS issue Andrew Johnson
RE: sscan/ saveData problem with RW permission, and not an NFS issue Vesna Samardzic-Boban
Prev: RE: Problem in installing asyn4-19 Mark Rivers
Next: Re: sscan/ saveData problem with RW permission, and not an NFS issue Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: sscan/ saveData problem with RW permission, and not an NFS issue Vesna Samardzic-Boban
