1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: How to create EPICS device support for a simple serial or GPIB device
To: Vahe Sahakyan <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 23 Apr 2013 12:20:47 +0000
Change this line:
dbLoadRecords("db/asynRecord.db","P=AB300,R=Test,PORT=L0,ADDR=0,IMAX=0,OMAX=0")
to this:
dbLoadRecords("$(ASYN)/db/asynRecord.db","P=AB300,R=Test,PORT=L0,ADDR=0,IMAX=0,OMAX=0")
You need to point to the correct directory containing the asynRecord.db file, and the $(ASYN) is needed to do this.
> 2). cas warning: Configured TCP port was unavailable.
You can ignore that warning, it is normal.
From: [email protected] [[email protected]] on behalf of Vahe Sahakyan [[email protected]]
Sent: Tuesday, April 23, 2013 5:49 AM
To: [email protected]
Subject: How to create EPICS device support for a simple serial or GPIB device
Hello,
I followed the instructions described in Eric Norum's "How to create EPICS
device support for a simple serial or GPIB device" paper. Everything goes
ok until I run the st.cmd. I got following message:
root@ubuntu:/home/diagnos/EpicsVG/ab300/iocBoot/iocAB300#
../../bin/linux-x86_64/AB300 st.cmd
dbLoadDatabase("../../dbd/AB300.dbd",0,0)
AB300_registerRecordDeviceDriver(pdbbase)
dbLoadRecords("../../db/devAB300.db","P=AB300:,R=,L=0,A=0")
# Create a diagnostic asynRecord
#cd ${AB300}
filename="../dbLexRoutines.c" line number=243
No such file or directory dbRead opening file db/asynRecord.db
#The following command is for a serial line terminal concentrator
drvAsynIPPortConfigure("L0","172.28.28.86:4001",0,0,0)
2013/04/23 11:43:19.175 Can't connect to 172.28.28.86:4001: Connection
refused L0 -1 autoConnect could not connect
#The following commands are for a local serial line
#drvAsynSerialPortConfigure("L0","/dev/ttyS0",0,0,0)
#asynSetOption("L0", -1, "baud", "9600")
#asynSetOption("L0", -1, "bits", "8")
#asynSetOption("L0", -1, "parity", "none")
#asynSetOption("L0", -1, "stop", "1")
#asynSetOption("L0", -1, "clocal", "Y")
#asynSetOption("L0", -1, "crtscts", "N")
asynSetTraceMask("L0",-1,0x9)
asynSetTraceIOMask("L0",-1,0x2)
iocInit()
Starting iocInit
## EPICS R3.14.12.2 $Date: Mon 2011-12-12 14:09:32 -0600$
## EPICS Base built Apr 16 2013
cas warning: Using dynamically assigned TCP port 38680,
cas warning: but now two or more servers share the same UDP port.
cas warning: Depending on your IP kernel this server may not be
cas warning: reachable with UDP unicast (a host's IP in
EPICS_CA_ADDR_LIST)
../online_notify.c: CA beacon (send to "172.28.28.127:5065") error was
"Connection refused"
Please, can anybody help me with my problems - What means:
1).
EPICS_CA_ADDR_LIST)
Thank you in advance,
Vahe.
RE: How to create EPICS device support for a simple serial or GPIB device Vahe Sahakyan
Prev: RE: Multiple copies of IOC Mogamad-Amien Crombie
Next: RE: How to create EPICS device support for a simple serial or GPIB device Vahe Sahakyan
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: How to create EPICS device support for a simple serial or GPIB device Vahe Sahakyan
