1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: asynPrint to print asyn port name
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 24 Apr 2013 23:50:18 +0000
That is a good suggestion.  I have been thinking of another extension to the asynTrace utility, which is an ASYN_TRACE_WARNING bit.  This would be used for messages whose severity is between ASYN_TRACE_ERROR and ASYN_TRACE_FLOW.
How about adding 3 more bits to the asyn trace mask:
ASYN_TRACE_WARNING
ASYN_TRACE_SHOW_PORT - display the port/addr information (=1 by default)
ASYN_TRACE_SHOW_TIME - display the timestamp (=1 by default)
From: [email protected] [[email protected]] on behalf of [email protected] [[email protected]]
Sent: Wednesday, April 24, 2013 3:51 AM
To: [email protected]
Subject: asynPrint to print asyn port name
Hello,
When writing asyn drivers I find myself using plenty of asynPrint calls to trace execution, debug etc. For each call I often find myself adding the current drivers asyn portname – and also often the asyn address.
The reason that I add the asyn port name to the asynPrint is of course to allow quickly identifying which asyn port is spewing out the message. In particular on operational systems with many devices and asyn drivers I usually have ASYN_TRACE_ERROR enabled by default – and then struggle to figure out which driver produced the error message.
Would it be possible to add printing of the asyn port name – and possibly the address – to the asynPrint call by default?
I think the relevant bit of code is in asyn/asynDriver/asynManger.c   - but the code there is rather more complex than I had imagined... :-)
Cheers,
Ulrik
Re: asynPrint to print asyn port name Eric Norum
Re: asynPrint to print asyn port name Mark Davis
asynPrint to print asyn port name ulrik.pedersen
Prev: RE: Help with JCA installation Mark Rivers
Next: Re: asynPrint to print asyn port name Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: asynPrint to print asyn port name Mark Davis
