1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Fwd:
To: [email protected]
Cc: [email protected]
Date: Fri, 26 Apr 2013 16:13:15 +0530
---------- Forwarded message ----------
Date: Fri, Apr 26, 2013 at 4:01 PM
Subject:
To:
Hi
We are trying to install Epics base with Ubuntu and got following error
Suggest.
Vishnu chaudhari (IPR)
bucketLib.o epicsRingPointer.o epicsRingBytes.o postfix.o calcPerform.o cvtFast.o resourceLib.o epicsOnce.o epicsSingletonMutex.o dbmf.o ellLib.o envSubr.o envData.o errlog.o errSymLib.o errSymTbl.o fdmgr.o fdManager.o freeListLib.o gpHashLib.o iocsh.o registry.o libComRegister.o iocLog.o logClient.o macCore.o macEnv.o macUtil.o aToIPAddr.o adjustment.o cantProceed.o epicsConvert.o epicsExit.o epicsStdlib.o epicsString.o truncateFile.o ipAddrToAsciiAsynchronous.o epicsUnitTest.o epicsThread.o epicsMutex.o epicsEvent.o epicsTime.o epicsMessageQueue.o epicsMath.o epicsGeneralTime.o osiClockTime.o osdSock.o osdSockAddrReuse.o osiSock.o systemCallIntMech.o epicsSocketConvertErrnoToString.o osdAssert.o osdFindSymbol.o osdInterrupt.o osdPoolStatus.o osdSignal.o osdEnv.o epicsReadline.o epicsTempFile.o epicsStdio.o osdStdio.o osdThread.o osdMutex.o osdEvent.o osdTime.o osdProcess.o osdNetIntf.o osdMessageQueue.o devLibVME.o devLibVMEOSD.o taskwd.o epicsTimer.o timer.o timerQueue.o timerQueueActive.o timerQueueActiveMgr.o timerQueuePassive.o tsDefs.o      -lpthread   -lreadline -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86/libCom.so.3.14
mkdir ../../../lib/linux-x86
ln -s libCom.so.3.14 ../../../lib/linux-x86/libCom.so
Installing library ../../../lib/linux-x86/libCom.a
Installing html ../../../html//freeList/freeList.html
mkdir ../../../html
mkdir ../../../html/freeList
Installing html ../../../html//gpHash/gpHash.html
mkdir ../../../html/gpHash
make[3]: Leaving directory `/home/sst-ldg-fs-ctrl/vishnu/myepics/base/src/libCom/O.linux-x86'
make -C O.linux-86 -f ../Makefile TOP=../../.. T_A=linux-86 install
make[3]: Entering directory `/home/sst-ldg-fs-ctrl/vishnu/myepics/base/src/libCom/O.linux-86'
make[3]: *** No rule to make target `../O.Common/osiFileName.h', needed by `inc'.  Stop.
make[3]: Leaving directory `/home/sst-ldg-fs-ctrl/vishnu/myepics/base/src/libCom/O.linux-86'
make[2]: *** [install.linux-86] Error 2
make[2]: Leaving directory `/home/sst-ldg-fs-ctrl/vishnu/myepics/base/src/libCom'
make[1]: *** [libCom.install] Error 2
make[1]: Leaving directory `/home/sst-ldg-fs-ctrl/vishnu/myepics/base/src'
make: *** [src.install] Error 2
sst-ldg-fs-ctrl@sstldgfsctrl-HP-Compaq-8200-Elite-MT-PC:~/vishnu/myepics/base$
Re: vishnu chaudhari
Prev: RE: caget delays Mark Rivers
Next: Re: asynPrint to print asyn port name Mark Davis
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: EDM using Invisiblity by color in a widget Isadoro Carlino
Next: Re: vishnu chaudhari
