1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Change in behavior of the fullPathName.pl
To: [email protected]
Date: Wed, 01 May 2013 17:24:28 -0400
I have a question about the behavior of the fullPathName.pl script in EPICS version R3.14.12.3.J0 compared
to previous EPICS versions.
I noticed in building EPICS and applications with version R3.14.12.3.J0 that the shared library paths get resolved to absolute paths instead of paths that have previously contained symbolic links. I tracked this new behavior down to a single line of code in the perl module "/epics/R3.14.12.3.J0/lib/perl/EPICS/Path.pm".
The line of code added is listed below.
"$abs = abs_path($abs) if -e $abs;"
We maintain the same directory paths using symbolic links between our development and operational file servers. If the paths to shared libraries are different the code running on the operational servers fails to find the shared libraries. Really wish there was a flag to select between the old and new behavior rather than editing "Path.pm".
What's the best way to resolve this issue?
Thanks in advance,
Scott Higgins
Jefferson Lab
Re: Change in behavior of the fullPathName.pl Andrew Johnson
Prev: Thread Handle Leak: EPICS Base on Windows giles.knap
Next: areaDetector driver for Princeton Instruments PICAM cameras? Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Thread Handle Leak: EPICS Base on Windows Andrew Johnson
Next: Re: Change in behavior of the fullPathName.pl Andrew Johnson
