1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS Extensions Compilation Errors
To: murad ali <[email protected]>
Cc: [email protected]
Date: Wed, 08 May 2013 11:56:57 +0200
On 02.05.2013 06:27, murad ali wrote:
After make changes in:
1.  /opt/epics/extensions/configure --> TOP=/opt/epics
Do not change TOP. You may chose to change INSTALL_LOCATION (or INSTALL_LOCATION_EXTENSIONS) to install your code to a different place but it you change TOP everything breaks.
Dirk
2. /opt/epics/extensions/config --> EPICS_BASE=/opt/epics/base
3.  The Result of Uname command is
root@murad-desktop:/opt/epics/extensions/configure# uname -a
Linux murad-desktop 2.6.38-8-generic #42-Ubuntu SMP Mon Apr 11 03:31:50
UTC 2011 i686 i686 i386 GNU/Linux
4. My Ubuntu is 11.04
root@murad-desktop:/opt/epics/extensions/src/medm# make
make -C printUtils buildInstall
make[1]: Entering directory `/opt/epics/extensions/src/medm/printUtils'
make -C O.linux-x86 -f ../Makefile.Host T_A=linux-x86 BUILD_TYPE=Host
buildInstall
make[2]: Entering directory
`/opt/epics/extensions/src/medm/printUtils/O.linux-x86'
../../../../idllib
make[2]: ../../../../idllib: Command not found
make[2]: *** [../../../../idllib] Error 127
make[2]: Leaving directory
make[1]: *** [buildInstall.linux-x86] Error 2
make[1]: Leaving directory `/opt/epics/extensions/src/medm/printUtils'
make: *** [printUtils.buildInstall] Error 2
Please Let me tell how to resolve these Errors.
An Early Response will be highly Appretiated.
Deep Regards.
Murad Ali
On Mon, Apr 29, 2013 at 8:52 AM, murad ali <[email protected]
<mailto:[email protected]>> wrote:
    I have Ubuntu 11.4 Installed. I want to Install EPICS Base and MEDM
    following Instructions on (Download the distributions tarballs from
    EPICS.doc attached) . please refer to Configure the Extensions
    Section in this File.
    EPICS Base is Installed and Compiled (Base Installation Attached)
    While Compiling MEDM the erorr occures during make (extensions error
    attached)
    kindly let me tell that how can I compile MEDM properly.
    Also what are other alternatives to MEDM. CSS is just like MEDM or
    some other thing.
    An Early Response is required
    Regards
    Murad Ali
EPICS Extensions Compilation Errors murad ali
Re: EPICS Extensions Compilation Errors murad ali
Prev: Two questions about CSS Geng, Zheqiao
Next: Re: Timer Queue crash J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS Extensions Compilation Errors murad ali
Next: Would like to add regular expressions to dbpr Zelazny, Michael Stanley
