Subject: |
Asyn-based TCP/VXI-11 interface to many devices |
Rod Nussbaumer <[email protected]> |
To: |
epics Techtalk <[email protected]> |
Date: |
Fri, 10 May 2013 09:43:23 -0700 |
Hi all.
We are planning for installation of new beamlines requiring
approximately 130 magnet power supplies. The proposed supplies (a few
different manufacturers and models being considered) may be controlled
using VXI-11/Telnet style interfaces, and using SCPI style commands.
This implies the use of StreamDevice + Asyn interfaces in EPICS IOCs. My
concern is about the scalability of ssyn with the large number of TCP
connections to the power supplies. Each power supply will require an
asyn IP port to be maintained. Until now, I have only configured
asyn-based applications using 2 or 3 ports on a single IOC. This seems
like a significant departure from what I consider a conventional system.
The IOC platform would probably be a VME hosted CPU running Linux, with
an ethernet interface dedicated as a kind of VXI-11 fieldbus. It is
possible, or likely, that control of the 130 supplies will be spread
across 2 or 3 hardware IOC hosts.
Does anyone have any experience with this kind of configuration? Any
problems to anticipate? Any problems that have known solutions? I am
planning to try some kind of simulation using multiple physical hosts,
possibly using multiple virtual hosts on each. Each host/virtual-host
would simulate a power supply. Does this seem like a representative test?
Thanks.
Rod Nussbaumer
ISAC Controls, TRIUMF
Vancouver, Canada
- Re: Asyn-based TCP/VXI-11 interface to many devices Eric Norum
Re: EDM Andrew Johnson
<2013>
2025
2026
about the interface MCA problem that Matlab can't read real-time image from areaDetector zengzr
<2013>
2025
2026
ANJ, 20 Apr 2015 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
