1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ~kernel/driver message
To: Sebastian Matkovich <[email protected]>
Cc: [email protected]
Date: Sat, 11 May 2013 08:23:17 -0700
Sebastion:
Since you say 'accessed as root' I will assume your OS is Linux. You haven't said what GPIB hardware (hence, what driver) you're using. Quite possibly, there is no need to develop device support. If your hardware is compatible with NI hardware or otherwise supported by the open source Linux GPIB drivers, then using those in conjunction with Asyn & StreamDevice is likely to be a recipe for success, especially if the power supply uses a SCPI style language. The only code you'll have to write doing this will be a protocol file that defines how EPICS records send and receive string data. Just using asyn (and asynRecord; highly under-appreciated) adds a great deal of value to the system and contributes greatly to the development process.
Rod Nussbaumer
ISAC Controls, TR|IUMF
Vancouver, Canada
Sebastian Matkovich wrote:
hey, does this kernel message say you anything? kernel: gpib: need to hold board lock to perform ioctl; i found the sourcecode writing this: if( current->pid != board->locking_pid )
printk( "gpib: need to hold board lock to perform ioctl %i\n",
cmd & 0xff );
retval = -EPERM;
goto done;
what i try is to build device support for a powersupply connected through a gpib interface. someone told me it might be because two different processes try to access the board, or maybe it isn't accessed by root (but i executed the ioc as root), has anyone got an idea?^^
~kernel/driver message Sebastian Matkovich
Prev: ~kernel/driver message Sebastian Matkovich
Next: channel archiver questions James F Ross
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: EPICS Engineer Required James Cooke
