1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Timer Queue crash
To: "J. Lewis Muir" <[email protected]>
Cc: EPICS <[email protected]>
Date: Mon, 13 May 2013 11:50:24 +0200
The problem went away after I re-compiled base. Maybe I had a version mismatch somewhere. Or a lib was broken during copy. Anyway, it works now!
Dirk
On 08.05.2013 17:15, J. Lewis Muir wrote:
On 5/8/13 4:37 AM, Dirk Zimoch wrote:
Hello,
I have a problem using epicsTimerQueueActive.
When I create a time queue with epicsTimerQueueActive::allocate(true)
then release it with epicsTimerQueueActive::release() and after that
call epicsTimerQueueActive::allocate(true) again, I get a segmentation
fault due to access to address 0.
I see no crash if I do not call release().
Interestingly, I see this effect only on my armv5teb (aka xscale_be)
embedded Linux system, but not on x86 or on p2020 ppc (big endian, too).
All accesses are in the same thread (_main_) during device initialization.
This happens when I use StreamDevice with at least two records connected
to a non-existing asynOctet port.
Any ideas?
Hi, Dirk.
What version of EPICS Base is this?
What compiler was used to build for armv5teb?
Does the problem also occur when built with all compiler optimizations
disabled (i.e. -O0)?
Lewis
RE: Timer Queue crash Hill, Jeff
Timer Queue crash Dirk Zimoch
Re: Timer Queue crash J. Lewis Muir
Prev: RE: CSS 3.1.x PVManager / JCA ClassCastException marcus . michalsky
Next: RE: CA subscription synchronisation shutdown problem michael.abbott
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Timer Queue crash J. Lewis Muir
Next: RE: Timer Queue crash Hill, Jeff
